> On Oct 28, 2020, at 4:13 PM, Douglas Araujo via Tech-talk <tech-talk at aps.anl.gov> wrote:
> when I run as sudo the ours script to start the IOC (that uses procServer), it don't get the root environment variables. So, I configured the script to get the local user environment variables when call the script as sudo
Generally, you should not run the IOC with root privileges as that opens up potential security risks. More typically, a service account is created specifically to run the IOC with privileges appropriate for what the IOC needs to access. The system service responsible for starting the IOC can su to the IOC account, set appropriate env variables, and start the IOC via procServer or otherwise.
Steven Hartman
hartmansm at ornl.gov
- Read PV value Attributes XML Douglas Araujo via Tech-talk
- RE: Read PV value Attributes XML Mark Rivers via Tech-talk
- Re: Read PV value Attributes XML Douglas Araujo via Tech-talk
- Re: Read PV value Attributes XML Johnson, Andrew N. via Tech-talk
Re: EPICS IOC and its client application with ONLY IPv6 Jeong Han Lee via Tech-talk
<2020>
2025
Reg multi monitor GUI in CSS Himanshu Tyagi via Tech-talk
<2020>
2025
