Subject: Re: LabView-EPICS Integration using SoftIoc
From: "Mostafa, Jalal \(IPE\) via Tech-talk" <[email protected]>
To: "Arnold, Ned D." <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Nov 2020 14:37:24 +0000
Hi Ned,
Timestamps would be coming from the LabView system in both cases.
- With the solution of the asynDriver, the timestamp would be a timestamp generated by real-time device with respect to the sensor.
- With shadowing the LabVIEW-based server, the timestamp would be the one that has been generated by the LabVIEW-based server. (Another disadvantage for NI EPICS module is that you cannot use TSE and TSEL)
Jalal
This is the best that we can do for timestamps.
Sent: Monday, November 2, 2020 3:27:31 PM
To: [email protected]; Mostafa, Jalal (IPE)
Another issue to consider is the timestamps applied to the EPICS records ...
  • Do they come from the LabView system or from the IOC?
  • How accurate can you make the timestamp?
  Ned
From: Tech-talk on behalf of Mostafa, Jalal (IPE) via Tech-talk
Sent: Monday, November 2, 2020 07:44 AM
Subject: LabView-EPICS Integration using SoftIoc
Hi all!
We have many systems from NI that we would like to integrate with EPICS
for the KATRIN experiment (katrin.kit.edu)
The old control system was written in LabView but we would like to
replace it with EPICS without rewriting the code again. Therefore, we
are looking for a nice LabView-EPICS integration.
We have seen two options for LabView:
- CALAB which does not work with realtime devices
- Official NI EPICS module. It is good but I can list several problems:
huge loss of EPICS features (it is only an implementation of CA plus
alarming, the other metadata and configuration fields are not available)
- not very developer-friendly (adding/removing PVs relies on shared
variables so it is time consuming)
Another two solutions we thought of:
1. Using AsynDriver and communicate with the realtime device using a TCP
protocol
2. Running an EPICS server on the realtime device using NI EPICS module
then shadowing it with a SoftIoc using CA links.
(a softIoc server running with input and output records to read and
write to the original LabView EPICS server)
I have several concerns here:
- Am I missing any other way to integrate LabView with EPICS? I would
like to hear from your experiences.
- Although solution (1) is time consuming, I am in favor of it but let's
check if we can do it more easily with solution (2). Anyway, can the
experts comment on its feasibility?
- Solution (2): What do you think about performance? Alarms? I/O Intr
are not available on a softIoc, so the developer has to use periodic
SCAN. How can I add custom SCAN periods?
Thanks for your help.
Best,
Jalal
Re: LabView-EPICS Integration using SoftIoc Arnold, Ned D. via Tech-talk
Prev: Re: LabView-EPICS Integration using SoftIoc Mark Rivers via Tech-talk
Next: EPICS How-To , Installation on Windows John Dobbins via Tech-talk
Prev: Re: LabView-EPICS Integration using SoftIoc Arnold, Ned D. via Tech-talk
Next: RE: LabView-EPICS Integration using SoftIoc Baily, Scott A via Tech-talk
