Subject: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Nov 2020 15:46:14 +0000
Hi all.
Buffer size is 48 because the device sends waveform data in lines so I read each line separately by reading 48 bytes, If I request ADC 200 for example I receive 200 lines where each line is 48 bytes. I even did a test where I used a buffer size of 1M to receive the full 20000 lines and still got the same error.
Regarding EPICS waveforms, what I meant is variable length from the client side; For example I set a buffer size in a PV and based on that PV value I read a specific length so that a plotter for example reads data with that specific length only. Does NORD achieve this? If yes, how does asyn access individual record's fields?.
Best Regards,
Abdalla.
Sent: Tuesday, November 3, 2020 7:18 PM
To: Mark Rivers <[email protected]>; Abdalla Ahmad <[email protected]>; [email protected] <[email protected]>
On 11/3/20 8:49 AM, Mark Rivers via Tech-talk wrote:
> -          I don’t think EPICS supports variable length waveform records.  You need to create the waveform record in dbLoadRecords with a size that is the largest you plan to use.  That is what areaDetector does with NDPluginStdArrays.
To clarify, waveform records have a _maximum_ size which is fixed
on initialization (eg. NELM).  Actually size (NORD) has long been
changeable at runtime in the range [0, NELM].
Some caveats about NORD==0 apply wrt. CA specifically (works fine with PVA).
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Abdalla Ahmad via Tech-talk
RE: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Michael Davidsaver via Tech-talk
Prev: caQtDM V4.3.0 Brands Helge (PSI) via Tech-talk
Next: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Prev: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Michael Davidsaver via Tech-talk
