Subject: New releases of the measComp module
Date: Fri, 20 Nov 2020 23:41:27 +0000
Folks,
Releases 2-5 and 2-5-1 of the measComp module are now available.
This is from the R2-5-1 release notes:
-drvMultiFunction.cpp
    - Fixed bug in waveform digitizer mode, current channel was being calculated incorrrectly.
    - Improved poller to reduce the number of error messages when the device is not available.
- E-1608::AInScanStart_E1608 (Linux)
    - Added 5 retries to start waveform acquisition. It appears that sometimes the connect() has not actually completed before acquisition is started, and the device returns a "not ready" status.
    - Improved error messages when acquisition does not start correctly.
    - Bug fix for 1-byte message not being sent correctly.
- mcBoard_E-1608.cpp (Linux)
    - Bug fix where lock was not taken when it should be.
This is from the R2-5 release notes:
- Improvements to USB-CTR04/08 support
    - Added support for reading the 8 digital I/O bits in the MCS scan. This allows capturing the status of input and output bits during a scan. There are now 9 MCS spectra: 8 for the counters and 1 for the digital I/O.
   - Added ability to select counters to use in the MCS on an individual basis, rather than the first and last counter to use. This also applies to the digital I/O word.
    - Added an AbsTimeWF waveform record containing the absolute time of each point in waveform digitizer and MCS scans.
    - Added support for cbDaqInScan and cbDaqSetTrigger on Linux.
    - Added TrigMode record to control the trigger mode of DaqInScan.
    - Fixed bugs on Linux when the number of counters selected was not a power of 2. The data could be wrong and it would stop before the number of channels to collect was reached.
- Added support for E-DIO24 module on Linux and Windows .
- Added autoconverted OPI files for edm, caQtDM, CSS-Boy and CSS-Phoebus.
- Updated the version of the Measurement Computing Windows UL library from 6.51 to 6.72.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
The source repository is on Github:
https://github.com/epics-modules/measComp
Cheers,
Prev: asyn connetion to wti Hawi Stecher via Tech-talk
Next: Re: asyn connetion to wti Eric Norum via Tech-talk
Prev: Re: asyn connetion to wti Maren Purves via Tech-talk
Next: Clean up library upon ioc exit Laurenz Rettig via Tech-talk
