Subject: Re: asyn connetion to wti
To: Hawi Stecher <[email protected]>
Cc: Eric Norum via Tech-talk <[email protected]>
Date: Fri, 20 Nov 2020 15:46:55 -0800
Sounds like the terminal server requires an RFC 2217 connection?  How did you configure the ASYN port?  Did you specify the ‘COM’ option?
On Nov 20, 2020, at 3:33 PM, Hawi Stecher via Tech-talk <[email protected]> wrote:
I am trying to connect a softIOC using asyn and StreamDevice to a wti console server, which has a serial connection to a LakeShore325.
I am able to telnet to the wti and communicate with the LakeShore. I am also able to connect the softIOC to other devices and send messages.
There seems to be some issue between asyn and the wti, which is serving a standard telnet connection.
Re: asyn connetion to wti Hawi Stecher via Tech-talk
Prev: New releases of the measComp module Mark Rivers via Tech-talk
Next: RE: asyn connetion to wti Mark Rivers via Tech-talk
Prev: asyn connetion to wti Hawi Stecher via Tech-talk
Next: Re: asyn connetion to wti Hawi Stecher via Tech-talk
