1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: device support for Keithley 2450
From: "Brown, Garth via Tech-talk" <tech-talk at aps.anl.gov>
To: "Siddons, David" <siddons at bnl.gov>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 30 Nov 2020 23:47:40 +0000
Hi David,
To run a program when the source meter boots, name it "autoexec.tsp" on a USB stick (or that's how our works, anyway). You can see that this file does a lot, but has a very simple interface with K2612B_RadFET.proto. I should note that there is a bug in here somewhere. Changing settings sometimes crashes something, and I haven't had a chance to look into it.
Garth
Sent: Thursday, November 26, 2020 11:36 AM
To: Brown, Garth <gwbrown at slac.stanford.edu>; EPICS Tech Talk <tech-talk at aps.anl.gov>
Hi Garth,
   Thanks for responding. Yes, please, I'd like to take a look at what you have. I have a specific set of test measurements I want to automate, which sounds similar to what you did.
Pete.
Sent: Wednesday, November 25, 2020 12:59 AM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>; Siddons, David <siddons at bnl.gov>
I have a streamdevice based IOC talking to their similar 2612. My code wouldn't be directly useful to you, but depending on how you plan to use the 2450, the approach might suit you. They support a flavor of Lua with their own extensions that they call TSP. It was easy to learn. Console input/output from a TSP program can be used to write your own commands which interface with streamdevice. I used that interface for initialization and setting parameters. The TSP program executes a complicated series of measurements with timing requirements and 100+ data points, then sends the set of data back to streamdevice asynchronously.
On the other hand, if you want it for a general purpose lab instrument, this approach might not be flexible enough.
Garth
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, November 24, 2020 6:28 AM
Subject: device support for Keithley 2450
HI Tech-Talkers,
Does anyone have support for the Keithley 2450 SourceMeter?
THanks,
Pete.
Attachment: autoexec.tsp
Description: autoexec.tsp
Attachment: K2612B_RadFET.proto
Description: K2612B_RadFET.proto
Attachment: 2612Channel.template
Description: 2612Channel.template
Attachment: 2612Common.template
Description: 2612Common.template
device support for Keithley 2450 Siddons, David via Tech-talk
Re: device support for Keithley 2450 Brown, Garth via Tech-talk
Re: device support for Keithley 2450 Siddons, David via Tech-talk
Prev: Re: archappl question Shankar, Murali via Tech-talk
Next: Looking for help on PMD101 EPICS driver yincx--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: device support for Keithley 2450 Siddons, David via Tech-talk
Next: ADEiger for EIGER2 John Dobbins via Tech-talk
ANJ, 01 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
