Hi Mark,
Thank you for the suggestion. The commands are different between these two models, but yes, I can start with the IP module.
Best,
-Ji Li
发件人: Mark Rivers <rivers at cars.uchicago.edu>
发送时间: 2020年12月2日 17:48 收件人: Li, Ji <liji at bnl.gov> 抄送: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov> 主题: RE: EPICS support for Harvard Pump 33 DDS Syringe Pump Hi Ji Li,
There is support in the ip module for the Harvard PHD2000 series syringe pumps (PHD2000.db, PHD2000.proto). I don’t know if the command sets of the Harvard 33 DDS and PHD2000 series are compatible, but it is probably at least a good starting point.
On Behalf Of Li, Ji via Tech-talk
Has anyone created EPICS support for Harvard Pump 33 DDS Syringe Pump?
-Ji Li ------------------------------------------------ Beamline Controls NSLS-II Brookhaven National Laboratory Upton, NY 11973 ------------------------------------------------
ANJ, 04 Dec 2020 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
