1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: multiple USB devices in Asyn
From: "Siddons, David via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 8 Dec 2020 21:19:11 +0000
Hi Mark, I just did "asynReport" on the runnogn IOC and got this:
epics> asynReport
IP1 multiDevice:No canBlock:Yes autoConnect:Yes
Serial line /dev/ttyUSB0: Connected
IP2 multiDevice:No canBlock:Yes autoConnect:Yes
Serial line /dev/ttyUSB1: Connected
ALM1 multiDevice:Yes canBlock:Yes autoConnect:Yes
Port: ALM1
ALM2 multiDevice:Yes canBlock:Yes autoConnect:Yes
Port: ALM2
So it seem ALM2 exists. So I don't understand the message.
Pete.
Sent: Tuesday, December 8, 2020 3:52 PM
To: Siddons, David <siddons at bnl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: multiple USB devices in Asyn
Can you send the complete output when you start the IOC?
Sent: Tuesday, December 8, 2020 2:49 PM
Hi Mark,
  Here is the code. I tried to send the whole IOC, but your mailer rejected it.
Pete.
Sent: Tuesday, December 8, 2020 2:36 PM
Hi Pete,
Where is the source code containing this driver?
almCreateEZ4Controller("ALM1", "IP1", "$(ALM_ADDR1)", 4, 200, 500)
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Siddons, David via Tech-talk
Sent: Tuesday, December 8, 2020 1:13 PM
To: tech-talk at aps.anl.gov
Subject: multiple USB devices in Asyn
I have a setup with two identical USB devices. They connect as ttyUSB0 and ttyUSB1. I tried to set up an asyn interface using the following commands:
drvAsynSerialPortConfigure("IP1", "/dev/ttyUSB0", 0, 0, 0)
asynSetOption("IP1", -1, "baud", "115200")
asynSetOption("IP1", -1, "bits", "8")
asynSetOption("IP1", -1, "parity", "none")
asynSetOption("IP1", -1, "stop", "1")
asynSetOption("IP1", -1, "clocal", "Y")
asynSetOption("IP1", -1, "crtscts", "N")
drvAsynSerialPortConfigure("IP2", "/dev/ttyUSB1", 0, 0, 0)
asynSetOption("IP2", -1, "baud", "115200")
asynSetOption("IP2", -1, "bits", "8")
asynSetOption("IP2", -1, "parity", "none")
asynSetOption("IP2", -1, "stop", "1")
asynSetOption("IP2", -1, "clocal", "Y")
asynSetOption("IP2", -1, "crtscts", "N")
# almCreateController(AllMotion port name, asyn port name, board address,
#                     Number of axes, Moving poll period (ms), Idle poll period (ms))
almCreateEZ4Controller("ALM2", "IP2", "$(ALM_ADDR2)", 4, 200, 500)
This fails, saying port ALM2 cannot be found. If I try to connect the second one also to ALM1, it complains that ALM1 is already registered.
If I comment out the first device, the second one (with port ALM2) comes up fine. How should I be doing this?
Pete.
multiple USB devices in Asyn Siddons, David via Tech-talk
RE: multiple USB devices in Asyn Mark Rivers via Tech-talk
Re: multiple USB devices in Asyn Siddons, David via Tech-talk
Prev: RE: multiple USB devices in Asyn Mark Rivers via Tech-talk
Next: Re: multiple USB devices in Asyn Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 08 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
