Hello,
We have a image that I believe is being accessed thru the gateway (one in a swarm of gateways, each proxying a different VLAN). I have some funky behavior that is probably a config issue. I am trying to interpret the output of pvget -d.
Without the -d, the behavior is as follows. Sometimes, I get this (the valid response)
$ pvget -r dimension SL1K2:EXIT:CAM:DATA1:Pva:Image
SL1K2:EXIT:CAM:DATA1:Pva:Image epics:nt/NTNDArray:1.0
union value
(none)
codec_t codec
Othertimes I get this (an invalid response)
SL1K2:EXIT:CAM:DATA1:Pva:Image $
And sometimes, I get a timeout.
With a -d, the valid response looks like so
$ pvget -d -r dimension SL1K2:EXIT:CAM:DATA1:Pva:Image
2020-12-10T09:50:38.242 Creating datagram socket from: 0.0.0.0:56065.
2020-12-10T09:50:38.242 Broadcast address #0: 172.21.159.255:5076. (not unicast)
2020-12-10T09:50:38.242 Broadcast address #1: 172.21.55.255:5076. (not unicast)
2020-12-10T09:50:38.242 Setting up UDP for interface 172.21.156.41/255.255.252.0, broadcast 172.21.159.255, dest <none>.
2020-12-10T09:50:38.242 Creating datagram socket from: 172.21.156.41:5076.
2020-12-10T09:50:38.242 Creating datagram socket from: 172.21.159.255:5076.
2020-12-10T09:50:38.242 Setting up UDP for interface 172.21.52.78/255.255.252.0, broadcast 172.21.55.255, dest <none>.
2020-12-10T09:50:38.242 Creating datagram socket from: 172.21.52.78:5076.
2020-12-10T09:50:38.242 Creating datagram socket from: 172.21.55.255:5076.
2020-12-10T09:50:38.242 Creating datagram socket from: 224.0.0.128:5076.
2020-12-10T09:50:38.242 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2020-12-10T09:50:38.242 Sending 76 bytes 0.0.0.0:56065 -> 172.21.159.255:5076.
2020-12-10T09:50:38.242 Sending 76 bytes 0.0.0.0:56065 -> 172.21.55.255:5076.
2020-12-10T09:50:38.242 UDP Client Rx (76) 172.21.159.255:5076 <- 172.21.156.41:56065
Waiting...
2020-12-10T09:50:38.242 UDP Client Rx (76) 172.21.55.255:5076 <- 172.21.52.78:56065
2020-12-10T09:50:38.243 UDP Client Rx (53) 0.0.0.0:56065 <- 172.21.156.251:60975
2020-12-10T09:50:38.243 Connecting to PVA server: 172.21.156.251:58333.
2020-12-10T09:50:38.243 Opening socket to PVA server 172.21.156.251:58333, attempt 1.
2020-12-10T09:50:38.243 Socket connected to PVA server: 172.21.156.251:58333.
2020-12-10T09:50:38.243 Acquiring transport to 172.21.156.251:58333.
2020-12-10T09:50:38.245 Connected to PVA server: 172.21.156.251:58333.
union value
(none)
codec_t codec
string format
string units
2020-12-10T09:50:38.257 Releasing TCP transport to 172.21.156.251:58333.
2020-12-10T09:50:38.258 TCP socket to 172.21.156.251:58333 is to be closed.
2020-12-10T09:50:38.258 UDP socket 0.0.0.0:0 closed.
The invalid response looks like so
2020-12-10T09:50:41.262 Creating datagram socket from: 0.0.0.0:36324.
2020-12-10T09:50:41.262 Broadcast address #0: 172.21.159.255:5076. (not unicast)
2020-12-10T09:50:41.262 Broadcast address #1: 172.21.55.255:5076. (not unicast)
2020-12-10T09:50:41.262 Setting up UDP for interface 172.21.156.41/255.255.252.0, broadcast 172.21.159.255, dest <none>.
2020-12-10T09:50:41.262 Creating datagram socket from: 172.21.156.41:5076.
2020-12-10T09:50:41.263 Creating datagram socket from: 172.21.159.255:5076.
2020-12-10T09:50:41.263 Setting up UDP for interface 172.21.52.78/255.255.252.0, broadcast 172.21.55.255, dest <none>.
2020-12-10T09:50:41.263 Creating datagram socket from: 172.21.52.78:5076.
2020-12-10T09:50:41.263 Creating datagram socket from: 172.21.55.255:5076.
2020-12-10T09:50:41.263 Creating datagram socket from: 224.0.0.128:5076.
2020-12-10T09:50:41.263 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2020-12-10T09:50:41.263 Sending 76 bytes 0.0.0.0:36324 -> 172.21.159.255:5076.
2020-12-10T09:50:41.263 Sending 76 bytes 0.0.0.0:36324 -> 172.21.55.255:5076.
2020-12-10T09:50:41.263 UDP Client Rx (76) 172.21.159.255:5076 <- 172.21.156.41:36324
Waiting...
2020-12-10T09:50:41.263 UDP Client Rx (76) 172.21.55.255:5076 <- 172.21.52.78:36324
2020-12-10T09:50:41.263 UDP Client Rx (53) 0.0.0.0:36324 <- 172.21.156.251:60975
2020-12-10T09:50:41.263 Connecting to PVA server: 172.21.156.251:58333.
2020-12-10T09:50:41.263 Opening socket to PVA server 172.21.156.251:58333, attempt 1.
2020-12-10T09:50:41.264 Socket connected to PVA server: 172.21.156.251:58333.
2020-12-10T09:50:41.264 Acquiring transport to 172.21.156.251:58333.
2020-12-10T09:50:41.266 Connected to PVA server: 172.21.156.251:58333.
2020-12-10T09:50:41.266 UDP Client Rx (53) 0.0.0.0:36324 <- 172.21.156.20:48998
SL1K2:EXIT:CAM:DATA1:Pva:Image 2020-12-10T09:50:41.276 Releasing TCP transport to 172.21.156.251:58333.
2020-12-10T09:50:41.276 TCP socket to 172.21.156.251:58333 is to be closed.
2020-12-10T09:50:41.276 UDP socket 0.0.0.0:0 closed.
The only different I see is this extra 2020-12-10T09:50:41.266 UDP Client Rx (53) 0.0.0.0:36324 <- 172.21.156.20:48998 in the invalid response.
How would I interpret this? I think we are taking to the same gateway (TCP socket to 172.21.156.251:58333 ) but I can't explain the two
different responses. Any help is appreciated.
Murali
