Subject: Re: Timestamping Confusion
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 14 Dec 2020 22:52:30 +0000
On Dec 14, 2020, at 4:43 PM, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Partial success so far, I was able to get the TSEL to grab the timestamp from another record that was set by TSE default 0 (sys clock I think this is?).  When I set TSE to -2 can you not write to the TIME field of a record like this
Caput mydevice:abc.TIME 2020-12-14 14:38:49.021827
I was hoping to simulate my digitizer setting the timestamp in my waveform record TIME field.
Sorry, the TIME field is not directly accessible through Channel Access at all, other than being readable as metadata (i.e. part of a DBR_TIME_xxx or similar data type). You can’t read or write a .TIME field directly, generally only a device support or a link type can set the TIME field of a record. The point of setting TSE to -2 is to tell the record that the device support has already set the TIME field and the record should not overwrite it with the current wall-clock time.
- Andrew
From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Monday, December 14, 2020 1:32 PM
To: EPICS tech-talk <[email protected]>
Subject: RE: Timestamping Confusion
Thank you both for the insight, it seems best for us to go a similar path of using TSEL to copy the timestamp from the digitizer to each of our waveform records and using TSE set to -2 to stop the IOC from overwriting the time field (please correct me if I am wrong on this). I think I just need to understand the best way to get the first timestamp and then use TSEL to pass it along to the other records.
Ralph when you stated to have the digitizer send the timestamp with the data, would I just have my digitizer set the TIME field in the waveform record then?
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Saturday, December 12, 2020 5:25 AM
To: EPICS Tech Talk <[email protected]>
On Fri, 11 Dec 2020 at 22:33, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Thanks for the comments Michael, when you are dealing with hundreds of waveform records and the timestamps are being taken when each record is processed (I would assume these would all be off by some delay if multiple softIOCs are running) do you then just have a master time waveform to lineup all your other signals to t0?  It seems the digitizer would have a time stamp of t0 for all of its signals but the epics records would not all align at the same timestamp since each one isn't processed at t0 to be timestamped.
The EPICS Device Support needs to know the timestamp t0 (preferably sent with the data by the digitizer) and write it to each record's timestamp when it updates the record.
In that case, by configuring their TSE to -2, all waveform records can use the digitizer timestamp. That timestamp can even be forwarded (using TSEL) through post-processing chains, so that processed data may still use the timestamp that the digitizer sent with the raw data at the beginning of the chain.
Cheers,
~Ralph
Complexity comes for free, simplicity you have to work for.
RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Re: Timestamping Confusion Michael Davidsaver via Tech-talk
Re: Timestamping Confusion Ralph Lange via Tech-talk
Prev: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Next: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
