1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Help
From: "Kunjir, Shriraj via Tech-talk" <tech-talk at aps.anl.gov>
To: Erika Jones <erikajon at umich.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 15 Dec 2020 11:58:12 +0000
You can try entering “export EPICS_HOST_ARCH=darwin-x86” in the terminal and then “make”
On Dec 14, 2020, at 5:21 PM, Erika Jones via Tech-talk <tech-talk at aps.anl.gov> wrote:
[EXTERNAL] This email originated from outside of FRIB
I am trying to download a base (base-3.15.7) onto my macbook. When I run "make" in the terminal, I get these errors:
    2 errors generated.
    make[4]: *** [caServer.o] Error 1
    make[3]: *** [install.darwin-x86] Error 2
    make[2]: *** [build.install] Error 2
    make[1]: *** [ca/legacy/pcas.install] Error 2
    make: *** [src.install] Error 2
    My version is MacOS Catalina.
Thank you,
Erika Jones
Help Erika Jones via Tech-talk
Prev: WebOPI does not accept parent macros Abdalla Ahmad via Tech-talk
Next: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Help Erika Jones via Tech-talk
Next: Re: Help Johnson, Andrew N. via Tech-talk
ANJ, 15 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
