Subject: Re: Intended use of NTMultiChannel
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
Date: Fri, 18 Dec 2020 05:15:04 +0000
Hi, Michael.
Thank you for the tip about using PVA link support. I’ve created a group with some PVs and the result looks like what I was trying to achieve with NTMultiChannel.
Two questions:
1 – Is there a way to call a function every time a group processes? I’d like to create a device-support-like thing to read the fields and values of each channel and calculate things.
2 – Is there a way to pvget individual fields of a group? Something like pvget grp:name.X.
Thank you,
Márcio Paduan Donadio
Control Systems Engineer - SLAC
Date: Thursday, December 17, 2020 at 7:28 AM
To: Paduan Donadio, Marcio <[email protected]>, [email protected] <[email protected]>
On 12/16/20 9:11 PM, Paduan Donadio, Marcio via Tech-talk wrote:
> I have a NTMultiChannel created using the C++ API.
Which c++ API specifically?
> I pvput to channelName passing a valid PV name. I placed a printf inside the process() method just to check if the record is processing and I can confirm it does.
> When I pvget I expected to see the other fields of the record populated with values from the PV in channelName. Is it intended that inside process() I write the commands to bring the data for each channel and write to the fields of the NTMultiChannel? Is there a default “record support” that has it already implemented and I can use?
If you are referring to pvDatabaseCPP, then probably not.  It is more analogous to PCAS.
You might look at the PVA link support as a way of having an IOC act as a PVA client.
https://epics-base.github.io/pva2pva/qsrv_page.html#qsrv_link
> Some data:
> Epics base 7.0.3
> $ pvget GMDTest:NTScalar
> GMDTest:NTScalar 0
> $ pvput GMDTest:NTMultiChannel 'channelName=["GMDTest:NTScalar"]'
> Old : epics:nt/NTMultiChannel:1.0
>     any[] value
>     string[] channelName []
>     int[] severity []
>     int[] status []
>     string[] message []
>     boolean[] isConnected []
> New : epics:nt/NTMultiChannel:1.0
>     any[] value
>     string[] channelName ["GMDTest:NTScalar"]
>     int[] severity []
>     int[] status []
>     string[] message []
> $ pvget GMDTest:NTMultiChannel
> GMDTest:NTMultiChannel epics:nt/NTMultiChannel:1.0
>     any[] value
>     int[] severity []
>     int[] status []
>     string[] message []
Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Intended use of NTMultiChannel Paduan Donadio, Marcio via Tech-talk
Prev: Re: Splitting a string in a protocol file Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Prev: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Next: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
