Subject: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db'
From: Juliane Reinhardt via Tech-talk <[email protected]>
To: Jeong Han Lee <[email protected]>
Cc: Jeong Lee <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 17 Dec 2020 23:14:51 -0800
Hi Han,
Thanks for the prompt reply. The repository is here: https://github.com/mp49/lakeshore Yes I saw these error but then when I looked into the dbd or db files I could not see what the actual issue was.
Juliane
On 12/17/20 23:11, Jeong Han Lee wrote:
Hi Juliane,
Your DBD file, example.dbd is wrong. So you have a lot of error
message in your IOC startup. Please see below "snip snip section"
Since I can get the code of this repository if this is public, could
you point me where your repository is?  I cc this email to my lab
account.
And ALS also has the similar db file, which you may get more benefit
from your IOC also.
Han
--- snip snip ---
dbLoadDatabase "dbd/example.dbd"\
Declaration of recordtype(scalcout) preceeded full definition.\
Error at or before "\}" in file "dbd/example.dbd" line 10293\
--- snip snip ---
On Thu, Dec 17, 2020 at 9:53 PM Juliane Reinhardt <[email protected]> wrote:
Hi everyone,
Thanks for your help to build the IOC.
I pulled the latest version with the sns specific template removed and
rebuilt the application after modifying the configure/RELEASE file. That
worked fine. However, when starting the IOC I get multiple errors. I
searched for solutions but wasn't successful yet. I would appreciate if
you could point me to some solution as I am still relatively new to
EPICS and with every IOC installation I learn more but only after
running into quite some issues. I attached the output of the ioc startup.
Best,
Juliane
On 12/15/20 07:27, Pearson, Matthew R. wrote:
Sorry about that. Steve is right, it's just a SNS specific template that shouldn't have been in the example IOC. I've removed the use of devIocStats from the example IOC on GitHub.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Hartman,
Steven via Tech-talk
Sent: Tuesday, December 15, 2020 9:15 AM
To: Jeong Han Lee <[email protected]>; Juliane Reinhardt
<[email protected]>
On Dec 15, 2020, at 2:27 AM, Jeong Han Lee via Tech-talk <tech-
   Please look at the example.substitutions file. It uses ioc_sns.db
within there. My first guess ioc_sns.db file is missing or is located
in a wrong directory.
ioc_sns.db is a local configuration file for customizing iocStats on the SNS
beam lines. It can be safely ignored / commented out.
Steven Hartman
[email protected]
Juliane Reinhardt, PhD
Project Scientist | ALS Computing Group
Blg. 15-337E | phone: 510-486-4313
[email protected]
Lawrence Berkeley National Lab
[email protected]
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Hartman, Steven via Tech-talk
RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Prev: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Next: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
