Subject: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db'
From: Jeong Han Lee via Tech-talk <[email protected]>
To: Juliane Reinhardt <[email protected]>
Date: Fri, 18 Dec 2020 00:06:13 -0800
Hi Juliane,
Please look at my forked version. Somehow, the calc record is missing,
since my streamDevice was compiled with a calc record. I guess your
stream device may be compiled with a calc record also.
https://github.com/jeonghanlee/lakeshore
I modified its makefile also, but this work is really quick-and-dirty.
I may have more mistakes.
There is another startup script you may see, it is more clean output,
because I remove autosave.
I am sure that SNS will solve this problem more fundamentally soon.
Until then, you may try to see how it works.
HTH,
Han
On Thu, Dec 17, 2020 at 11:14 PM Juliane Reinhardt <[email protected]> wrote:
> Hi Han,
> Thanks for the prompt reply. The repository is here:
> https://github.com/mp49/lakeshore
> Yes I saw these error but then when I looked into the dbd or db files I
> could not see what the actual issue was.
> Juliane
> On 12/17/20 23:11, Jeong Han Lee wrote:
> > Hi Juliane,
> > Your DBD file, example.dbd is wrong. So you have a lot of error
> > message in your IOC startup. Please see below "snip snip section"
> > Since I can get the code of this repository if this is public, could
> > you point me where your repository is?  I cc this email to my lab
> > account.
> > And ALS also has the similar db file, which you may get more benefit
> > from your IOC also.
> > Han
> > --- snip snip ---
> > dbLoadDatabase "dbd/example.dbd"\
> > Declaration of recordtype(scalcout) preceeded full definition.\
> > Error at or before "\}" in file "dbd/example.dbd" line 10293\
> > --- snip snip ---
> > On Thu, Dec 17, 2020 at 9:53 PM Juliane Reinhardt <[email protected]> wrote:
> >> Hi everyone,
> >> Thanks for your help to build the IOC.
> >> I pulled the latest version with the sns specific template removed and
> >> rebuilt the application after modifying the configure/RELEASE file. That
> >> worked fine. However, when starting the IOC I get multiple errors. I
> >> searched for solutions but wasn't successful yet. I would appreciate if
> >> you could point me to some solution as I am still relatively new to
> >> EPICS and with every IOC installation I learn more but only after
> >> running into quite some issues. I attached the output of the ioc startup.
> >> Best,
> >> Juliane
> >> On 12/15/20 07:27, Pearson, Matthew R. wrote:
> >>> Hi,
> >>> Sorry about that. Steve is right, it's just a SNS specific template that shouldn't have been in the example IOC. I've removed the use of devIocStats from the example IOC on GitHub.
> >>> Cheers,
> >>> Matt
> >>>> -----Original Message-----
> >>>> From: Tech-talk <[email protected]> On Behalf Of Hartman,
> >>>> Steven via Tech-talk
> >>>> Sent: Tuesday, December 15, 2020 9:15 AM
> >>>> To: Jeong Han Lee <[email protected]>; Juliane Reinhardt
> >>>> <[email protected]>
> >>>> Cc: tech-talk <[email protected]>
> >>>>> On Dec 15, 2020, at 2:27 AM, Jeong Han Lee via Tech-talk <tech-
> >>>>>    Please look at the example.substitutions file. It uses ioc_sns.db
> >>>>> within there. My first guess ioc_sns.db file is missing or is located
> >>>>> in a wrong directory.
> >>>> ioc_sns.db is a local configuration file for customizing iocStats on the SNS
> >>>> beam lines. It can be safely ignored / commented out.
> >>>> Steven Hartman
> >>>> [email protected]
> >> Juliane Reinhardt, PhD
> >> Project Scientist | ALS Computing Group
> >> Blg. 15-337E | phone: 510-486-4313
> >> [email protected]
> >> Lawrence Berkeley National Lab
> [email protected]
RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Hartman, Steven via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Prev: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Next: Re: synApps_6_1 build error on windows-x64 with EPICS 7 Markus Huber via Tech-talk
Next: RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
