Subject: Question about the font name for EDM
To: EPICS tech-talk <[email protected]>
Date: Tue, 29 Dec 2020 04:07:56 +0000
Deal all,
Recently I have update centos 7 to the version: CentOS Linux release 7.8.2003 (Core)
However, edm cannot be run correctly as before, the new problem is as follows when typing edm command in the terminal:
No such font available: [-*-century schoolbook l-medium-r-normal--0-80-75-75-p-0-*-*]
Last line processed: 12
Font init failed - abort
I have already set the following command in bashrc:
xset fp+ /usr/share/X11/fonts/75dpi
and the problem still occurs.
Maybe I should install new font and I have no idea what the font name is I should type using yum install command.
Thank you in advance.
Prev: Re:RE: Huber SMC 9300 controller Dongliang via Tech-talk
Next: RE: Reading multiple parameters from an incoming message. Mark Rivers via Tech-talk
Prev: 回复: Reading multiple parameters from an incoming message. Li, Ji via Tech-talk
Next: Re: Question about the font name for EDM 米清茹 via Tech-talk
