1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re:RE: Huber SMC 9300 controller
From: Dongliang via Tech-talk <tech-talk at aps.anl.gov>
To: "Oram, Dominic (STFC,RAL,ISIS)" <dominic.oram at stfc.ac.uk>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 25 Dec 2020 16:31:13 +0800 (CST)
Hi Dom,
I wrote a Model 3 motor driver for Huber SMC9300 controller with MCB4B driver as an example.
There is the example that is a total of less than 400 lines of code:
https://github.com/epics-motor/motorAcs/blob/master/acsApp/src/MCB4BDriver.cpp
https://github.com/epics-motor/motorAcs/blob/master/acsApp/src/MCB4BDriver.h
if necessary, I will send you my driver support.
Best regards,
Dongliang
At 2020-12-08 20:05:11, "Oram, Dominic (STFC,RAL,ISIS)" <dominic.oram at stfc.ac.uk> wrote:
Hello Dongliang,
We would also like to control a Huber SMC9000 series. Did you find any device support for it? It seems LNLS may have been working on the same thing (https://epics.anl.gov/tech-talk/2017/msg01534.php)
We would be happy to write support ourselves if there isn’t any already.
Dom
Senior Software Engineer
ISIS Neutron and Muon Source
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of yangdl via Tech-talk
Sent: 13 March 2020 02:14
To: tech-talk at aps.anl.gov
Subject: Huber SMC 9300 controller
I'm new to EPICS and trying to use EPICS to control the Huber SMC9300 motor controller.
Does anybody have an EPICS driver support for the Huber SMC9300.
Could you give me any advice?
Dongliang
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Huber SMC 9300 controller yangdl via Tech-talk
RE: Huber SMC 9300 controller Oram, Dominic (STFC,RAL,ISIS) via Tech-talk
Prev: 回复: Reading multiple parameters from an incoming message. Li, Ji via Tech-talk
Next: Question about the font name for EDM lzf neu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: RE: Huber SMC 9300 controller Oram, Dominic (STFC,RAL,ISIS) via Tech-talk
Next: PyDM setting alarm with PVView example Rute Mendes via Tech-talk
ANJ, 28 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
