Hello!
I've the latest version of PyDM installed and I was trying PVView for testing the possibility of using PyDM's EPICS CA aware widgets within a different application. Only that the following line doesn't work for me, On pvview.py module, widget.useAlarmState = True I can only have the alarm active when using PyDM launcher. Am I missing something? Do I have to follow the "note" requirements, referred on the link below, to use a PyDM widget on my code, by including PyDMApplication? Thank you for attention. I hope I can have your help. Kind regards, Rute
ANJ, 26 Dec 2020 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
