1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: PicoHarp 300
Date: Tue, 19 Jan 2021 16:30:50 +0000
Does anyone have a ready-to-use db file (picoharp.db) for PicoHarp 300?
I managed to build the pico library from source codes: https://github.com/Araneidae/picoharp , but failed to generate the db file because the building process seems heavily dependent on Diamond Light Source internal environment.
Another question: has anyone managed to use a USB-to-Ethernet converter to control PicoHarp 300 through the EPICS driver?
Yong
The following is my configuration and tests:
configure/RELEASE:
EPICSDBBUILDER = /home/yhu/epicsdbbuilder
configure/CONFIG_SITE:
PYTHON = /usr/bin/python
make[2]: Leaving directory `/direct/iocs_diagnostics/picoharp/picoharpApp/src'
make -C ./Db install
make[2]: Entering directory `/direct/iocs_diagnostics/picoharp/picoharpApp/Db'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/direct/iocs_diagnostics/picoharp/picoharpApp/Db/O.linux-x86'
/usr/bin/python ../picoharp.py ../O.Common/picoharp.db
Traceback (most recent call last):
  File "../picoharp.py", line 1, in <module>
    from support import *
  File "/direct/iocs_diagnostics/picoharp/picoharpApp/Db/support.py", line 12, in <module>
    from epicsdbbuilder import *
ImportError: No module named epicsdbbuilder
make[3]: *** [../O.Common/picoharp.db] Error 1
$ ipython
In [1]: from epicsdbbuilder import  *
In [2]: pwd
Out[2]: u'/home/yhu/epicsdbbuilder'
Re: PicoHarp 300 Michael Davidsaver via Tech-talk
Prev: Re: Can't enable custom frame rates for a basler camera in area detector Mark Rivers via Tech-talk
Next: RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: PVXS release 0.2.1 Michael Davidsaver via Tech-talk
Next: Re: PicoHarp 300 Michael Davidsaver via Tech-talk
