1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PicoHarp 300
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Date: Wed, 20 Jan 2021 09:10:26 -0800
On 1/19/21 8:30 AM, Hu, Yong via Tech-talk wrote:
> Does anyone have a ready-to-use db file (picoharp.db) for PicoHarp 300?
> I managed to build the pico library from source codes: https://github.com/Araneidae/picoharp <https://github.com/Araneidae/picoharp> , but failed to generate the db file because the building process seems heavily dependent on Diamond Light Source internal environment.
> Another question: has anyone managed to use a USB-to-Ethernet converter to control PicoHarp 300 through the EPICS driver?
I recently had cause to run an old/cheap oscilloscope with software
usb over ethernet using usbip on Linux[1].  This worked well as an
ad hoc setup which I only needed for an afternoon.
However, even in that time it was obvious that re-connection,
or recovery from USB device reset, are not handled well.
I had to manually unbind/re-bind, and restart my application, each
time to get things working again.  I wouldn't want to try to keep
a setup like this running for an extended period.
[1] as in 'apt-get install usbip'
PicoHarp 300 Hu, Yong via Tech-talk
Prev: RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Manoussakis, Adamandios via Tech-talk
Next: RE: CS-Studio (Phoebus) Dynamic Population of PVs in GUI Pearson, Matthew R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: PicoHarp 300 Hu, Yong via Tech-talk
Next: Re: PicoHarp 300 Abbott, Michael (DLSLtd, RAL, LSCI) via Tech-talk
