1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Can I open a CSS Phoebus layout from the command line
From: "Phillip A. Sorensen via Tech-talk" <[email protected]>
Date: Mon, 25 Jan 2021 21:27:32 +0000
Good People of Tech-Talk,
I am working on upgrading from the old CSS/Eclipse alarm server to the
CSS/Phoebus alarm server.  I have the server and the new phoebus client
running and created a layout for the alarms.
I can open it from the Window->Open Layout menu, but I was wondering if
there is a way to open a layout from a command line parameter.  I would
like to create a wrapper that starts phoebus with the alarm layout.
Phil Sorensen
Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Prev: Re: Channel connection performance Veseli, Sinisa via Tech-talk
Next: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: changing unit string to scale factor Zimoch Dirk (PSI) via Tech-talk
