1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Channel connection performance
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
Date: Mon, 25 Jan 2021 20:42:57 +0000
If you are already using pvaClientCPP, you could also take a look at the MultiChannel class (examples can be found here: https://github.com/epics-base/exampleCPP/tree/master/exampleClient/src)
Here is how long it takes on my machine to connect and retrieve values for 1000 CA channels using pvapy (both client and IOC are running on the same machine):
>>> import time
>>> from pvaccess import *
>>> cList = ['X%s' % i for i in range (1,1001)]
>>> c = MultiChannel(cList, CA)
>>> t0 = time.time(); pv=c.get(); t1=time.time() ; print(t1-t0)
0.21088194847106934
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
Sent: Monday, January 25, 2021 2:19 PM
To: Axel Terfloth <[email protected]>
Cc: [email protected] <[email protected]>
On 1/25/21 11:00 AM, Axel Terfloth via Tech-talk wrote:
> Hello,
> i’m new to EPICS and take a closer look at it for evaluation purpose. To obtain a better understanding I started to dig deeper by implementing some tests which are based on the C++ examples. From a functional point of view everything I tried works nicely so far. Also the performance is generally very good in most of my test scenarios. Nevertheless one issue i came across is the time required for connecting to a channel  via PVA. In this scenario I set up 4000 process variables and implement one client which implements high frequency put and get access to a quarter (1000) of these proces variables. On my machine (which runs all processes for now) if takes about 250ms for a single channel connection. Once all channels are connected is really fast. Nevertheless connecting 1000 pvs takes more than 6 minutes. I currently connect channel by channel using the PvaClient API in my tests. Is there a more efficient way to connect to a large set of channels?  I would appreciate any hint.
Can you be more specific about what you application is doing?  A common source
of slowdown with CA or PVA clients is for user code the is to perform network
operations in sequence.  This can be done in parallel, which can give a nice speedup.
You might want to investigate my new (hopefully replacement) PVA library
which makes it easy to run many operations in parallel.
https://mdavidsaver.github.io/pvxs/
eg. the equivalent of 'pvget'
https://github.com/mdavidsaver/pvxs/blob/d0e82744d30256e36585b51af2704cc01a938e18/tools/get.cpp#L109-L132
If this isn't an option, then is the 'pvac' wrapper API which provides a
similar abstraction, though with more verbose syntax.
http://epics-base.github.io/pvAccessCPP/
eg. parallel get operations
http://epics-base.github.io/pvAccessCPP/examples_getme.html
Re: Channel connection performance Hu, Yong via Tech-talk
Channel connection performance Axel Terfloth via Tech-talk
Re: Channel connection performance Michael Davidsaver via Tech-talk
Prev: RE: changing unit string to scale factor Mark Rivers via Tech-talk
Next: Can I open a CSS Phoebus layout from the command line Phillip A. Sorensen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Channel connection performance Michael Davidsaver via Tech-talk
Next: Re: Channel connection performance Hu, Yong via Tech-talk
