1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: EPICS Module mrfioc2
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Tue, 26 Jan 2021 10:42:12 +0000
Hi
I came across this module https://github.com/epics-modules/mrfioc2 when searching for a driver for MRM-based timing system hardware. Looking at the source code it does not seem to work with Ethernet connected hardware, only VME. Our timing system hardware is inserted into a VME chassis but connected to the control system via the board’s Ethernet interface. Can this driver be configured to connect to Ethernet-connected hardware?
Thanks.
Abdalla.
Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Re: EPICS Module mrfioc2 Michael Davidsaver via Tech-talk
Prev: Re: changing unit string to scale factor Zimoch Dirk (PSI) via Tech-talk
Next: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Python cothread errors Ha, Kiman via Tech-talk
