1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Python cothread errors
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Kongtawong, Sukho" <[email protected]>
Date: Tue, 26 Jan 2021 14:51:00 +0000
Thanks, Yong,
Solved after increase timeout. caget takes ~12 seconds for all waveform readout.
Sent: Tuesday, January 26, 2021 9:44 AM
To: Ha, Kiman <[email protected]>; [email protected]
Cc: Kongtawong, Sukho <[email protected]>
Subject: Re: Python cothread errors
Kiman,
The default timeout for cothread caget is 5-second. Since you are reading lots of waveforms from lots of different IOCs (and it also depends on the network traffic), you might need to increase the “timeout” to a higher value, i.e. 30-second: caget(fa_x_pv, timeout=30, count=record_len)
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Kiman Ha <[email protected]>
Date: Tuesday, January 26, 2021 at 12:20 AM
Subject: Python cothread errors
Hi All,
We were trying to collect waveform data from the single point softIOC, a total of 180 * 100,000 points.
Before, it works fine, but recently, we found unexpected cothread error messages.
Can someone advise how to fix these errors?
$python save_sdi_no_trig.py test2
start: number of data: 100000
  burst length: 11 s
  read data...
Traceback (most recent call last):
  File "save_sdi_no_trig.py", line 83, in <module>
    faX  = caget(fa_x_pv, count=record_len)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 739, in caget
    return caget_array(pvs, **kargs)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 636, in caget_array
    for pv in pvs])
  File "/usr/lib/python2.7/dist-packages/cothread/cothread.py", line 1047, in WaitForAll
    result.append(event.Wait(timeout))
  File "/usr/lib/python2.7/dist-packages/cothread/cothread.py", line 661, in __run
    self.__function(*self.__args, **self.__kargs))
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 122, in throw_wrapper
    return function(pv, *args, **kargs)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 624, in caget_one
    return ca_timeout(done, timeout, pv)
  File "/usr/lib/python2.7/dist-packages/cothread/catools.py", line 149, in ca_timeout
    raise ca_nothing(name, cadef.ECA_TIMEOUT)
cothread.catools.ca_nothing: SR:SDI2FA:C23{BPM3}ADMA-X: User specified timeout on IO operation expired
# Global SDI data collection script
import os
import sys
import h5py
import matplotlib.pyplot as plt
import time
import datetime
import cothread
#from scipy import *
#from numpy import *
from cothread.catools import *
#from cothread import Timedout
# input parameters
comment = sys.argv[1]
save_dir = 'HLA_result'
burst_len_sp = 11 # time to store data in CC buffer [s]
record_len = 100000 # number of data to read from PVs
update_n_check = 5
update_t_wait = 1
# start
t0 = time.time()
print('start: number of data: ' + str(record_len))
init_burst_len = caget('SR:SDI2FA{}BurstLen-SP')
if (init_burst_len != burst_len_sp):
    caput('SR:SDI2FA{}BurstLen-SP', burst_len_sp)
    print('  set new burst length to ' + str(burst_len_sp) + ' s')
else:
    print('  burst length: ' + str(init_burst_len) + ' s')
# directories and filename
if not(os.path.exists(save_dir)):
    os.mkdir(save_dir)
suffix = datetime.datetime.now().strftime("%Y%m%d_%H%M_%S")
filename = 'SR_CCSDI_FA_' + suffix + '_'+ comment + '.h5'
# generate PVs
# normal BPM
prefix_data = []
prefix_bad = []
p_index = ['1','2','3','4','5','6']
Cell_index = ['30','01','02','03','04','05','06','07','08','09','10','11','12','13','14','15','16','17','18','19','20','21','22','23','24','25','26','27','28','29']
for i in Cell_index:
    for j in p_index:
        prefix_data.append('SR:SDI2FA:C'+i+'{BPM'+j+'}')
        prefix_bad.append('SR:C'+i+'-APHLA{BPM:'+j+'}')
# ID BPM (only upto 8 BPMs max)
p_index = ['7','8']
Cell_index = ['02','03','04','05','07','08','10','11','12','16','17','18','19','21','23','28']
    for j in p_index:
fa_x_pv = []
fa_y_pv = []
bad_x_pv = []
bad_y_pv = []
for i in range(len(prefix_data)):
    fa_x_pv.append(prefix_data[i] + 'ADMA-X')
    fa_y_pv.append(prefix_data[i] + 'ADMA-Y')
    bad_x_pv.append(prefix_bad[i] + 'PSD:BadX-Cmd')
    bad_y_pv.append(prefix_bad[i] + 'PSD:BadY-Cmd')
# collect data
I = caget('SR:C03-BI{DCCT:1}I:Total-I') # beam current
fin_cnt = caget('SR:SDI2FA{}TrigCnt-I') # initial trigger count
# read data from PVs
print('  read data...')
t = time.time()
faY  = caget(fa_y_pv, count=record_len)
badX = caget(bad_x_pv)
badY = caget(bad_y_pv)
print('    (lasted ' + str(round(time.time() - t, 2)) + ' s)')
# save .h5 file
print('  save hdf file...')
t = time.time()
fid = h5py.File(os.path.join(save_dir, filename), 'w')
fid['I'] = I
fid['prefix'] = prefix_data
fid['faX'] = faX
fid['faY'] = faY
fid['badX'] = badX
fid['badY'] = badY
fid['trig_cnt'] = fin_cnt
fid.close()
print('complete...(' + str(round(time.time() - t0, 2)) + ' s)')
Python cothread errors Ha, Kiman via Tech-talk
Re: Python cothread errors Hu, Yong via Tech-talk
Prev: Re: Python cothread errors Hu, Yong via Tech-talk
Next: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
