1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Problem using PyEpics and pvaPy at the same time on Windows
Date: Fri, 29 Jan 2021 23:52:17 +0000
I ran into a program running a Python program that uses both PyEpics and pvaPy.  Here I describe the problem and the solution.
It works fine on Linux:
corvette:iocBoot/iocTomoScan_13BM_PSO/autosave>conda activate base
(base) corvette:iocBoot/iocTomoScan_13BM_PSO/autosave>python
Python 3.7.3 (default, Mar 27 2019, 22:11:17)
[GCC 7.3.0] :: Anaconda, Inc. on linux
Type "help", "copyright", "credits" or "license" for more information.
Imported history from: '/home/epics/.pyhist'
>>> import epics
>>> import pvaccess
>>> epics.caget('13BMD:m1')
-5.250001587314
On Windows it works fine to run PyEpics by itself:
(base) C:\Users\tomo_user>python
Python 3.7.4 (default, Aug  9 2019, 18:34:13) [MSC v.1915 64 bit (AMD64)] :: Anaconda, Inc. on win32
>>> import epics
-5.250001587314
However, if I also load pvaccess I get this error:
>>> import epics
>>> import pvaccess
Traceback (most recent call last):
  File "C:\ProgramData\Anaconda3\lib\site-packages\epics\ca.py", line 373, in initialize_libca
    libca = load_dll(find_libca())
  File "C:\ProgramData\Anaconda3\lib\ctypes\__init__.py", line 442, in LoadLibrary
    return self._dlltype(name)
  File "C:\ProgramData\Anaconda3\lib\ctypes\__init__.py", line 364, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: [WinError 127] The specified procedure could not be found
[cid:292fe37f-72a4-462e-a05f-674aed70857d]
Matt Newville told me the problem is because PyEpics and pvaPy must load the same version of ca.dll.  pvaccess loads this version at import time:
C:\ProgramData\Anaconda3\Lib\site-packages\pvaccess\ca.dll
PyEpics by default loads this version upon the first "real connection":
C:\ProgramData\Anaconda3\Lib\site-packages\epics\clibs\win64\ca.dll
They are not the same and so the error occurs.
However, PyEpics allows setting the environment variable PYEPICS_LIBCA to define the location of ca.dll.
I set it to the same as pvaccess:
set PYEPICS_LIBCA=C:\ProgramData\Anaconda3\Lib\site-packages\pvaccess\ca.dll
and now I can run both PyEpics and pvaPy at the same time:
(base) C:\ProgramData>python
>>> import epics
>>> import pvaccess
-5.250001587314
I thought others might find this useful some day.
PNG image
Prev: Job opportunity at Sigray David Vine via Tech-talk
Next: RE: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: modbus write registers error to Pilz PLC 高振华 via Tech-talk
