1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 31 Jan 2021 07:18:09 +0000
Hi Kay,
I have been looking through the src and I am a little confused on how to actually get the exported array data out.  I see you have this iterator here to cycle through each value for each timestamp
                final VType value = iter.next();
then you turn that VType into a double using
                values.add(VTypeHelper.toDouble(value));
Does iter return the start of each array index if it’s an array of values or is it only returning the first index?
If Value is a VNumberArray is there a way to add it to the values list if I make it a List of Arrays instead of a List of Doubles?
Thanks
Sent: Friday, January 29, 2021 5:32 AM
To: [email protected]; Manoussakis, Adamandios <[email protected]>
Subject: Re: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue
> spreadsheet data shows up just fine..
> matlab files seem to be exporting just a single index per record
Yes, the Matlab export code only handles scalars.
In case of array data, you get the first element.
The code in question is this for the Matlab 'text file' *.m export
and this for the Matlab 'binary' *.mat export
In both places you'll see that it calls VTypeHelper.toDouble to try and turn the sample which might be double, enum, int, short, ... into a scalar for export.
You could try to update that code to check for VNumberArray and then export all array elements.
-Kay
RE: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue Manoussakis, Adamandios via Tech-talk
Re: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue Kasemir, Kay via Tech-talk
Prev: Problem using PyEpics and pvaPy at the same time on Windows Mark Rivers via Tech-talk
Next: modbus write registers error to Pilz PLC 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue bob dalesio via Tech-talk
Next: RE: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue Manoussakis, Adamandios via Tech-talk
