On 2/2/21 5:04 AM, Simon Rose via Tech-talk wrote:
> Hello -
> I am trying to understand how to register a cpp function for an EPICS aSub record (or something similar). In particular, I am trying to understand where and how to use the extern “C” directive.
While in theory I think that extern "C" could effect calling convention, in
practice it does not. So the only place extern "C" is needed is around
the epicsExport*() macros.
The actual global symbol name is determined by the epicsExport*,
which is working from a pointer to your function, so c++ name mangling
isn't relevant.
> From what I understand, the extern “C” directive is there to tell the c++ compiler to use C-style linking and name mangling. This seems reasonable for any function that is going to be exposed as a function that could be used outside of my specific library, e.g. by an aSub record.
> The function that is actually calling the aSub function is do_sub from aSubRecord.c. For reference:
> static long do_sub(aSubRecord *prec)
> GENFUNCPTR pfunc = prec->sadr;
> long status;
> if (prec->snam[0] == 0)
> return 0;
> if (pfunc == NULL) {
> recGblSetSevr(prec, BAD_SUB_ALARM, INVALID_ALARM);
> return S_db_BadSub;
> status = pfunc(prec);
> if (status < 0)
> recGblSetSevr(prec, SOFT_ALARM, prec->brsv);
> else
> prec->udf = FALSE;
> return status;
> And the function is called in the line
> Given that this is from a .c file and not a .cpp file, does pfunc need to be defined with extern “C” linkage? The closest analog that I can find is from asyn, specifically asynPortDriver.cpp, which defines a number of functions such as
> extern "C" {static asynStatus disconnect(void *drvPvt, asynUser *pasynUser)
> And these functions are later added into interfaces that, as I understand, are called from other parts of the code, hence their C-style linkages.
> Unfortunately, the example from the documentation seems to be implicitly in C, so that doesn’t help.
> In summary, my question is roughly as follows:
> 1. For a function defined in a .cpp file which is to be used as either the INAM or SNAM parameter in an aSub record, does that function need to be declared extern “C”?
> 2. What about the epicsExportFunction() line? What is the relationship between these two, and do either/both/none of them need to be extern “C”d?
> Thanks for your help,
> Cheers,
> Simon Rose
> Software Engineer
> European Spallation Source
- Re: Extern "C" when defining aSub records Till Straumann via Tech-talk
- Extern "C" when defining aSub records Simon Rose via Tech-talk
Questions about Pilatus detectors / latency Ralph Lange via Tech-talk
<2021>
2025
<2021>
2025
