To clarify and
illustrate what Michael was saying (= if you use the epics
export & registry
facilities you do not have to use extern "C" at all; in fact, your subroutine may even have static linkage!): a) Your C++ code you want to be executed from aSub foo.cc: #include <aSubRecord.h>b) DBD snippet (to be included by your application's dbd): foo.dbd: # this snippet ensures the boiler-plate code in foo.cc is # *executed* after the dbd is loaded registrar(register_func_foo) c) DB using 'foo': record(aSub, "FooSub") { HTH - Till PS: under the hood, EPICS uses a global variable to publish the address of 'static void register_func_foo()' to the linker and this way avoids name-mangling issues. On 2/2/21 4:54 PM, Michael Davidsaver via Tech-talk wrote: On 2/2/21 5:04 AM, Simon Rose via Tech-talk wrote:Hello - I am trying to understand how to register a cpp function for an EPICS aSub record (or something similar). In particular, I am trying to understand where and how to use the extern “C” directive.While in theory I think that extern "C" could effect calling convention, in practice it does not. So the only place extern "C" is needed is around the epicsExport*() macros. The actual global symbol name is determined by the epicsExport*, which is working from a pointer to your function, so c++ name mangling isn't relevant.From what I understand, the extern “C” directive is there to tell the c++ compiler to use C-style linking and name mangling. This seems reasonable for any function that is going to be exposed as a function that could be used outside of my specific library, e.g. by an aSub record. The function that is actually calling the aSub function is do_sub from aSubRecord.c. For reference: static long do_sub(aSubRecord *prec) { GENFUNCPTR pfunc = prec->sadr; long status; if (prec->snam[0] == 0) return 0; if (pfunc == NULL) { recGblSetSevr(prec, BAD_SUB_ALARM, INVALID_ALARM); return S_db_BadSub; } status = pfunc(prec); if (status < 0) recGblSetSevr(prec, SOFT_ALARM, prec->brsv); else prec->udf = FALSE; return status; } And the function is called in the line status = pfunc(prec); Given that this is from a .c file and not a .cpp file, does pfunc need to be defined with extern “C” linkage? The closest analog that I can find is from asyn, specifically asynPortDriver.cpp, which defines a number of functions such as extern "C" {static asynStatus disconnect(void *drvPvt, asynUser *pasynUser) { … }} And these functions are later added into interfaces that, as I understand, are called from other parts of the code, hence their C-style linkages. Unfortunately, the example from the documentation seems to be implicitly in C, so that doesn’t help. In summary, my question is roughly as follows: 1. For a function defined in a .cpp file which is to be used as either the INAM or SNAM parameter in an aSub record, does that function need to be declared extern “C”? 2. What about the epicsExportFunction() line? What is the relationship between these two, and do either/both/none of them need to be extern “C”d? Thanks for your help, Cheers, -- Simon Rose Software Engineer European Spallation Source
ANJ, 02 Feb 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
