1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: setcap and nosuid
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Siddons, David" <siddons at bnl.gov>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Tue, 2 Feb 2021 09:13:27 -0800
On 2/2/21 8:57 AM, Siddons, David wrote:
> Hi David,
> Yes, I saw that. Changing it doesn't seem to help:
> sudo chmod g+w /dev/mem
> ls -l /dev/mem
> crw-rw---- 1 root kmem 1, 1 Feb  1 21:05 /dev/mem
> ./regrw R 1   ( a program which maps the FPGA registers to userspace)
> Reading Register 1
> Can't open /dev/mem
Have you tried chmod 0666 to make sure this is really a permission problem?
The "Can't open" could also print 'errno'.
Also, I feel obligated to repeat myself in recommending against using
/dev/mem in any kind of long term solution.  There are safer ways
to grant access to specific MMIO ranges.
https://epics.anl.gov/tech-talk/2020/msg02201.php
Re: setcap and nosuid Siddons, David via Tech-talk
setcap and nosuid Michael Davidsaver via Tech-talk
Re: setcap and nosuid Michael Davidsaver via Tech-talk
Prev: Re: Extern "C" when defining aSub records Till Straumann via Tech-talk
Next: Re: setcap and nosuid Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: setcap and nosuid Siddons, David via Tech-talk
ANJ, 02 Feb 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
