1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: Questions about Bruker QM100 detector
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 3 Feb 2021 13:10:44 +0000
Hi Abdalla,
I would recommend using the Dante.  I wrote that driver recently, and I am using it in production.  The IOC run on Linux or Windows. You need a Windows system to do the initial configuration via USB.
The Canberra QM100 is very old.  It can communicate via a serial port, but that is very slow for reading spectra.  It can also communicate via a high-speed proprietary interface, but that is so old I would be surprised if there are Windows 10 drivers for it.
When you say "soft x-ray", what energy x-rays are you planning to measure?  I am not sure what the noise floor is on either of those electronics for measuring very low-energy x-rays.  What type of detector is it, Si(Li), Si drift diode, Ge, etc.?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, February 3, 2021 12:45 AM
To: tech-talk at aps.anl.gov
Subject: Questions about Bruker QM100 detector
Hello Community!
A soft X-ray beamline will be built at SESAME soon and the detector to be used is the Bruker QM100. I know that the MCA module supports this detector, but under windows only, and our standard OS is CentOS for every control system. So my question is, if anyone developed an IOC for this detector under windows, can you please share your experience running the IOC? What was your setup (Windows, compiler, EPICS and modules)? Were there any difficulties in building and running the IOC, data acquisition, etc. or any other issue?
One of our colleagues suggested that we might use the DANTE digital pulse processor from XGLab as a readout system for the QM100, it has an EPICS driver and Ethernet interface so that is another route we can go. Does anyone have experience with this pulse processor?
Best Regards,
Abdalla.
RE: Questions about Bruker QM100 detector Abdalla Ahmad via Tech-talk
Prev: Re: PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL] Mark Rivers via Tech-talk
Next: RE: Questions about Bruker QM100 detector Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Questions about Bruker QM100 detector Abdalla Ahmad via Tech-talk
ANJ, 03 Feb 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
