1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: How To Compile EPICS7 at RTEMS5.1
From: Heinz Junkes via Tech-talk <[email protected]>
To: 程司农 <[email protected]>
Cc: [email protected]
Date: Fri, 5 Feb 2021 17:12:01 +0100
Hallo chengsn,
you mixed up cpu types
MVME5500 != MVME2500
MVME5500 is a older one with PPC603(?)
MVME2500 is with qoriq_e500.
MVME5500, in the moment does works with the old stack only (—enable-networking).
At the moment there are also activities at gemini (Felix Kraemer) to get the MVME5500 running with EPICS7 and RTEMS5.1.
I have only used the MVME6100 (beatnik) so far. The MVME5500 is built a bit different and uses e.g. other network interfaces.
Heinz
> On 5. Feb 2021, at 14:53, 程司农 via Tech-talk <[email protected]> wrote:
> Hello EPICS/RTEMS users,
> I want to complie RTEMS at CentOS7, and get started EPICS with RTEMS, and my target board is mvme5500.So, I choose RTEMS5.1 and EPICS7 . I find some imformation in the https://epics.mpg.de/index.php?n=Software.EPICSRTEMS?userlang=en. I change the file configure/os/CONFIG_SITE.Common.RTEMS, then make RTEMS_BSP=mvme5500, there will be many .h header files missing. After adding a part, the rtems/bsd/modules.h file is now missing.
> There is my env:
> HOST: centOS7, Target board: mvme5500, RTEMS version: 5.1, EPICS version: 7.0(download from https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0 )
> The build is stopping with following error:
> [chengsn@localhost epicsBaseOwnPlayground-7.0]$ make RTEMS_BSP=mvme5500
> make -C ./configure install
> make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure'
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
>     T_A=linux-x86_64 install
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.linux-x86_64'
> make[2]: Nothing to be done for `install'.
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.linux-x86_64'
> make -C O.RTEMS-qoriq_e500 -f ../Makefile TOP=../.. \
>     T_A=RTEMS-qoriq_e500 install
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.RTEMS-qoriq_e500'
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure/O.RTEMS-qoriq_e500'
> make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure'
> make -C ./src install
> make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src'
> make -C ./tools install
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.linux-x86_64'
> Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
> mkdir ../../../lib
> mkdir ../../../lib/perl
> mkdir ../../../lib/perl/EPICS
> Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
> Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
> Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
> Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
> Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
> Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
> mkdir ../../../bin
> mkdir ../../../bin/linux-x86_64
> Installing script ../../../bin/linux-x86_64/convertRelease.pl
> Installing script ../../../bin/linux-x86_64/cvsclean.pl
> Installing script ../../../bin/linux-x86_64/depclean.pl
> Installing script ../../../bin/linux-x86_64/dos2unix.pl
> Installing script ../../../bin/linux-x86_64/expandVars.pl
> Installing script ../../../bin/linux-x86_64/fullPathName.pl
> Installing script ../../../bin/linux-x86_64/installEpics.pl
> Installing script ../../../bin/linux-x86_64/makeMakefile.pl
> Installing script ../../../bin/linux-x86_64/makeTestfile.pl
> Installing script ../../../bin/linux-x86_64/mkmf.pl
> Installing script ../../../bin/linux-x86_64/munch.pl
> Installing script ../../../bin/linux-x86_64/podToHtml.pl
> Installing script ../../../bin/linux-x86_64/podRemove.pl
> Installing script ../../../bin/linux-x86_64/replaceVAR.pl
> Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
> Installing script ../../../bin/linux-x86_64/useManifestTool.pl
> Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
> Installing html ../../../html/./style.css
> mkdir ../../../html
> mkdir ../../../html/.
> Installing generated html ../../../html/./EPICS/Getopts.html
> mkdir ../../../html/./EPICS
> Installing generated html ../../../html/./EPICS/Path.html
> Installing generated html ../../../html/./EPICS/Readfile.html
> Installing generated html ../../../html/./fullPathName.html
> Installing generated html ../../../html/./munch.html
> Installing generated html ../../../html/./podToHtml.html
> Installing generated html ../../../html/./podRemove.html
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.linux-x86_64'
> make -C O.RTEMS-qoriq_e500 -f ../Makefile TOP=../../.. \
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.RTEMS-qoriq_e500'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools/O.RTEMS-qoriq_e500'
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/tools'
> make -C template/base install
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.linux-x86_64'
> Installing script ../../../../bin/linux-x86_64/makeBaseApp.pl
> Installing ../../../../templates/makeBaseApp/top/Makefile
> mkdir ../../../../templates
> mkdir ../../../../templates/makeBaseApp
> mkdir ../../../../templates/makeBaseApp/top
> Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
> mkdir ../../../../templates/makeBaseApp/top/configure
> Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
> Installing ../../../../templates/makeBaseApp/top/configure/Makefile
> Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
> Installing ../../../../templates/makeBaseApp/top/configure/RULES
> Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
> Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
> Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
> Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile
> mkdir ../../../../templates/makeBaseApp/top/supportApp
> Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
> mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
> Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile
> mkdir ../../../../templates/makeBaseApp/top/supportApp/src
> Installing ../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.linux-x86_64'
> make -C O.RTEMS-qoriq_e500 -f ../Makefile TOP=../../../.. \
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.RTEMS-qoriq_e500'
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base/O.RTEMS-qoriq_e500'
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/base'
> make -C template/ext install
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext'
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.linux-x86_64'
> Installing script ../../../../bin/linux-x86_64/makeBaseExt.pl
> Installing ../../../../templates/makeBaseExt/top/Makefile
> mkdir ../../../../templates/makeBaseExt
> mkdir ../../../../templates/makeBaseExt/top
> Installing ../../../../templates/makeBaseExt/top/README
> Installing ../../../../templates/makeBaseExt/top/configure/CONFIG
> mkdir ../../../../templates/makeBaseExt/top/configure
> Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
> Installing ../../../../templates/makeBaseExt/top/configure/Makefile
> Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
> Installing ../../../../templates/makeBaseExt/top/configure/RULES
> Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
> Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
> Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
> Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
> mkdir ../../../../templates/makeBaseExt/top/configure/os
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
> Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc
> Installing ../../../../templates/makeBaseExt/top/src/Makefile
> mkdir ../../../../templates/makeBaseExt/top/src
> Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
> mkdir ../../../../templates/makeBaseExt/top/exampleExt
> Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
> Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
> Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
> mkdir ../../../../templates/makeBaseExt/top/simpleExt
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.linux-x86_64'
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.RTEMS-qoriq_e500'
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext/O.RTEMS-qoriq_e500'
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src/template/ext'
> make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/src'
> make -C ./test install
> make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test'
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools'
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.linux-x86_64'
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.linux-x86_64'
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.RTEMS-qoriq_e500'
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools/O.RTEMS-qoriq_e500'
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test/tools'
> make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/test'
> make -C ./modules install
> make[1]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules'
> make -C ./libcom install
> make[2]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom'
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure'
> make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.linux-x86_64'
> Installing CFG file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/cfg/CONFIG_LIBCOM_MODULE
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/cfg
> Installing CFG file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/cfg/CONFIG_LIBCOM_VERSION
> perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/convertRelease.pl checkRelease
> make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.linux-x86_64'
> make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.RTEMS-qoriq_e500'
> make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure/O.RTEMS-qoriq_e500'
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/configure'
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src'
> make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.linux-x86_64'
> Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/bldEnvData.pl
> perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/convertRelease.pl -T ../.. /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/libcomModuleDirs.pm
> perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/bldEnvData.pl  -t linux-x86_64 \
>  -c gcc -s Linux /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure
> Generating envData.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include           -MM -MF envData.d  envData.c
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/valgrind/valgrind.h
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/valgrind
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/libComVersion.h
> Installing generated generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/libComVersionNum.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/asLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/asTrapWrite.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/bucketLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/postfix.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/cvtFast.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAlgorithm.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsExcept.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/resourceLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsDLList.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsSLList.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsMinMax.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/tsFreeList.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsSingleton.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsGuard.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/dbmf.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/ellLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/envDefs.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsPrint.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/errMdef.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/errSymTbl.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/errlog.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/fdManager.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/fdmgr.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/flex.skel.static
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/freeList.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/gpHash.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/iocsh.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/initHooks.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/registry.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/libComRegister.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/iocLog.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/logClient.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/macLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/alarm.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/alarmString.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/adjustment.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/cantProceed.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/dbDefs.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsConvert.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsExit.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStdlib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsString.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTypes.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/shareLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsExport.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/unixFileName.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/locationException.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/ipAddrToAsciiAsynchronous.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compilerDependencies.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsUnitTest.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/testMain.h
> Installing generated generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsVersion.h
> Installing compiler dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc/compilerSpecific.h
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osiFileName.h
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiSock.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdSock.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsInterrupt.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdInterrupt.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsMutex.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdMutex.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsSpin.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsEvent.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdEvent.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsMath.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdMessageQueue.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdStrtod.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAssert.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsFindSymbol.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiPoolStatus.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdPoolStatus.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdThread.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsThread.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTime.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsGeneralTime.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdTime.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/generalTimeSup.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiClockTime.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsSignal.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiProcess.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osiUnistd.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/osiWireFormat.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdWireFormat.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdWireConfig.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAtomic.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsAtomicDefault.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsAtomicOSD.h
> Installing compiler dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc/epicsAtomicCD.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsEndian.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsReadline.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsMessageQueue.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStdio.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStdioRedirect.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTempFile.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsGetopt.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsStackTrace.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/devLib.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/devLibVME.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/devLibVMEImpl.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/osdVME.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsMMIO.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux/epicsMMIODef.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsThreadPool.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsRingPointer.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsRingBytes.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/taskwd.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsTimer.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_alloc.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_common.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_gen.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/yajl_parse.h
> Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/antelope
> /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/antelope -bparse -l -d ../../src/flex/parse.y
> mv parse.tab.c parse.c
> mv parse.tab.h parse.h
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c parse.c
> /usr/bin/g++ -o e_flex  -L/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64 -Wl,-rpath,/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64           -rdynamic -m64         epicsTempFile.o ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
> Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/e_flex
> /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/e_flex -S/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/flex.skel.static -8 -I -oasLib_lex.c ../../src/as/asLib_lex.l
> /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/antelope -basLib  ../../src/as/asLib.y
> mv asLib.tab.c asLib.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF asLib.d  asLib.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF parse.d  parse.c
> make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.linux-x86_64'
> Installing PERL_MODULES file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/perl/EPICS/macLib.pm
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c asLib.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/Linux -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c envData.c
> /usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
> /usr/bin/ranlib libCom.a
> /usr/bin/g++ -o libCom.so.3.17.2 -shared -fPIC -Wl,-hlibCom.so.3.17.2 -L/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64 -Wl,-rpath,/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64           -rdynamic -m64         asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
> Installing shared library /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64/libCom.so.3.17.2
> ln -s libCom.so.3.17.2 /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64/libCom.so
> Installing library /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64/libCom.a
> /usr/bin/g++ -o iocLogServer  -L/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64 -Wl,-rpath,/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
> Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/S99logServer
> Installing created executable /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/iocLogServer
> make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.RTEMS-qoriq_e500'
> perl -CSD /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/bldEnvData.pl  -t RTEMS-qoriq_e500 \
>  -c gcc -s RTEMS /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/configure
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc  -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF envData.d  envData.c
> /bin/mv asLib.tab.c asLib.c
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc  -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -MM -MF asLib.d  asLib.c
> make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src/O.RTEMS-qoriq_e500'
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osiFileName.h
> mkdir /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdSock.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdInterrupt.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdMutex.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdEvent.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsMath.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdMessageQueue.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdStrtod.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdPoolStatus.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdThread.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdTime.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osiUnistd.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdWireFormat.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdWireConfig.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsAtomicOSD.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsGetopt.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/osdVME.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsMMIO.h
> Installing OS dependent include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS/epicsMMIODef.h
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c asLib.c
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS-posix -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c envData.c
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-ar rc   libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-ranlib libCom.a
> Installing library /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/lib/RTEMS-qoriq_e500/libCom.a
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/src'
> make -C ./RTEMS install
> make[3]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS'
> make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.linux-x86_64'
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsRtemsInitHooks.h
> Installing generic include file /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/epicsMemFs.h
> Installing script /home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/bin/linux-x86_64/epicsMakeMemFs.pl
> make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.linux-x86_64'
> make[4]: Entering directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.RTEMS-qoriq_e500'
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I. -I.. -I../posix -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c ../posix/rtems_init.c
> ../posix/rtems_init.c: In function 'initialize_local_filesystem':
> ../posix/rtems_init.c:193:17: warning: unused variable '_FlashSize' [-Wunused-variable]
>      extern char _FlashSize[]  __attribute__((weak));
> ../posix/rtems_init.c:192:17: warning: unused variable '_FlashBase' [-Wunused-variable]
>      extern char _FlashBase[] __attribute__((weak));
> ../posix/rtems_init.c:191:17: warning: unused variable '_DownloadLocation' [-Wunused-variable]
>      extern char _DownloadLocation[] __attribute__((weak));
> ../posix/rtems_init.c: In function 'default_network_dhcpcd':
> ../posix/rtems_init.c:686:14: warning: implicit declaration of function 'rtems_dhcpcd_start'; did you mean 'rtems_telnetd_start'? [-Wimplicit-function-declaration]
>          sc = rtems_dhcpcd_start(NULL);
>               rtems_telnetd_start
> ../posix/rtems_init.c: In function 'POSIX_Init':
> ../posix/rtems_init.c:699:25: warning: unused variable 'cp' [-Wunused-variable]
>      char               *cp;
> /home/chengsn/MVME5500/RTEMS/rtems-5/bin/powerpc-rtems5-gcc --pipe -B/home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=7450 -mtune=7450                   -DUNIX      -O2 -g -ffunction-sections -fdata-sections   -Wall          -D__LINUX_ERRNO_EXTENSIONS__  -I. -I../O.Common -I. -I. -I.. -I../posix -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/compiler/gcc -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include/os/RTEMS -I/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/include        -c ../posix/rtems_config.c
> In file included from /home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/include/machine/rtems-bsd-config.h:230:0,
>                  from ../posix/rtems_config.c:92:
> /home/chengsn/MVME5500/RTEMS/rtems-5/powerpc-rtems5/mvme5500/lib/include/bsp/nexus-devices.h:40:10: fatal error: rtems/bsd/modules.h: No such file or directory
>  #include <rtems/bsd/modules.h>
> compilation terminated.
> make[4]: *** [rtems_config.o] Error 1
> make[4]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS/O.RTEMS-qoriq_e500'
> make[3]: *** [install.RTEMS-qoriq_e500] Error 2
> make[3]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom/RTEMS'
> make[2]: *** [RTEMS.install] Error 2
> make[2]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules/libcom'
> make[1]: *** [libcom.install] Error 2
> make[1]: Leaving directory `/home/chengsn/MVME5500/EPICS/epicsBaseOwnPlayground-7.0/modules'
> make: *** [modules.install] Error 2
> Did I do something wrong?
> Best regards,
> chengsn
Attachment: smime.p7s
Description: S/MIME cryptographic signature
How To Compile EPICS7 at RTEMS5.1 程司农 via Tech-talk
Prev: Re: How To Compile EPICS7 at RTEMS5.1 Joel Sherrill via Tech-talk
Next: Creating calc record in Python softioc Paul Nord via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
