1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: Creating calc record in Python softioc
From: Paul Nord via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 5 Feb 2021 12:23:22 -0600
According to the documentation, this should work:
#!/usr/local/epics/modules/pythonIoc/pythonIoc
from softioc import softioc, builder
builder.SetDeviceName('XX')
rec = builder.aIn('VALUE')
calc = builder.records.calc('CALC', CALC = 'A*B', A = rec, B = 42)
rec.FLNK = builder.PP(calc)
It chokes when assigning rec to input A.
  File "/usr/local/epics/modules/epicsdbbuilder/epicsdbbuilder/recordbase.py", line 190, in __ValidateField
    self._validate.ValidFieldValue(fieldname, str(value))
  File "/usr/local/epics/modules/epicsdbbuilder/epicsdbbuilder/dbd.py", line 111, in ValidFieldValue
    'Can\'t write "%s" to field %s: %s' % (value, name, message)
AssertionError: Can't write "XX:VALUE" to field A: not a number
Does anyone have a working example of using a calc record in python softioc?
Paul
Re: Creating calc record in Python softioc Johnson, Andrew N. via Tech-talk
Prev: Re: How To Compile EPICS7 at RTEMS5.1 Heinz Junkes via Tech-talk
Next: Re: Creating calc record in Python softioc Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
ANJ, 05 Feb 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
