1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Firmware upgrade for MRF event generators and receivers
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Tue, 9 Feb 2021 06:37:51 +0000
Hello Michael
Thanks for the feedback. Will try to contact MRF.
Side question, the firmware on MRF website is it for the processor or the FPGA or both? Should I update the processor only or both?
Best Regards,
Abdalla.
-----Original Message-----
Sent: Monday, February 08, 2021 7:32 PM
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Subject: Re: Firmware upgrade for MRF event generators and receivers
On 2/8/21 6:37 AM, Abdalla Ahmad via Tech-talk wrote:
> Hello community
> This question is not EPICS specific, but I could use some help. We tried downgrading the firmware for spare EVG and EVR boards which have the MRM firmware 005 I think to firmware E403 and D507 respectively. I followed the procedure in the manuals but when I issue the command "u" to start the update process, the telnet session exits with message "Self-programming triggered". I came back after a while and every time I telnet to the board, it seems the device entered a mode where no command is available (only q and x commands), sometimes when the device reboots, I try to dump the memory I get "Addr 0x8000002e: error -1".
> I tried re-uploading the firmware, power-cycle, and factory settings but nothing works. Any advice how to fix the firmware update process?
Back when I was at BNL I was able to successfully update firmware on several VME boards (I assume that's what you have).  I was always nervous though.
I can only recommend contacting MRF.  If you are lucky, and have access to a JTAG programmer, you might be able to directly re-flash the firmware yourself.
Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
Prev: caproto ioc alarm value leakage Troup, Euan (CASS, Marsfield) via Tech-talk
Next: 答复: Question about databrowser of CSS lzf neu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
Next: Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
