1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: caproto ioc alarm value leakage
From: "Troup, Euan \(CASS, Marsfield\) via Tech-talk" <[email protected]>
Date: Tue, 9 Feb 2021 05:00:02 +0000
Hi tech-talk,
I’m not sure if t his is the right forum, but I have a bit of a problem with a caproto-based IOC and alarms. The problem is if I have a PV that is updated with an alarm, a separate PV seems to inherit the alarm value when the second PV is updated.  If this is due to write-combining for efficiency, is there a way to turn it off? I have based the IOC on the io_interrupt.py example from the caproto package. The IOC code is below, and also some output from camonitor showing the alarms on the 2 PVs:
cheers,
Euan
import threading
import time
from caproto.server import pvproperty, PVGroup, ioc_arg_parser, run
def start_monitor(nv_callback):
    f = 1.0
    while True:
        time.sleep(1.0)
        nv_callback(f)
        f = (f + 1) % 20
class IOInt(PVGroup):
    stringv = pvproperty(value = '', record='stringin', max_length = 10)
    floatv = pvproperty(value = 0.0, record = 'ai', upper_alarm_limit = 18.0)
    @floatv.startup
    async def floatv(self, instance, async_lib):
        queue = async_lib.ThreadsafeQueue()
        thread = threading.Thread(target = start_monitor, daemon = True, kwargs = dict(nv_callback = queue.put))
        thread.start()
        while True:
            value = await queue.async_get()
            await self.stringv.write(str(value))
            await self.floatv.write(value)
if __name__ == '__main__':
    ioc_options, run_options = ioc_arg_parser(default_prefix = 'tio:', desc = 'test i/o interrupt')
    ioc = IOInt(**ioc_options)
    run(ioc.pvdb, **run_options)
camonitor -S tio:floatv tio:stringv
tio:floatv                     2021-02-09 15:48:12.750651 13
tio:stringv 2021-02-09 15:48:12.750228 13.0
tio:stringv 2021-02-09 15:48:13.751457 14.0
tio:floatv                     2021-02-09 15:48:13.755341 14
tio:stringv 2021-02-09 15:48:14.752766 15.0
tio:floatv                     2021-02-09 15:48:14.753228 15
tio:stringv 2021-02-09 15:48:15.753765 16.0
tio:floatv                     2021-02-09 15:48:15.754194 16
tio:stringv 2021-02-09 15:48:16.754858 17.0
tio:floatv                     2021-02-09 15:48:16.755291 17
tio:stringv 2021-02-09 15:48:17.755992 18.0
tio:floatv                     2021-02-09 15:48:17.756392 18 HIHI MAJOR
tio:stringv 2021-02-09 15:48:17.755992 18.0 HIHI MAJOR
tio:stringv 2021-02-09 15:48:18.757027 19.0 HIHI MAJOR
tio:floatv                     2021-02-09 15:48:18.757424 19 HIHI MAJOR
tio:stringv 2021-02-09 15:48:19.758113 0.0 HIHI MAJOR
tio:floatv                     2021-02-09 15:48:19.758522 0 LOLO MAJOR
tio:stringv 2021-02-09 15:48:19.758113 0.0 LOLO MAJOR
tio:stringv 2021-02-09 15:48:20.759297 1.0 LOLO MAJOR
tio:floatv                     2021-02-09 15:48:20.759772 1
tio:stringv 2021-02-09 15:48:21.760480 2.0
tio:floatv                     2021-02-09 15:48:21.760907 2
Re: caproto ioc alarm value leakage Lauer, Ken via Tech-talk
Prev: RE: [EXTERNAL] Re: Question about compress records Guyotte, Greg via Tech-talk
Next: RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: ADPilaus + NDFileHDF5 John Dobbins via Tech-talk
Next: Re: caproto ioc alarm value leakage Lauer, Ken via Tech-talk
