1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Firmware upgrade for MRF event generators and receivers
From: Jeong Han Lee via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Tue, 9 Feb 2021 00:36:00 -0800
Hi Abdalla,
On Mon, Feb 8, 2021 at 11:47 PM Abdalla Ahmad
<[email protected]> wrote:
> Hello Han
> We are using the EVG230 and EVR230-RF. There should not be any problem because I used to telnet to the board and dump the memory to check some registers according to the manual.
Still this is unclear to me, but I can assume you have a VME model for
EVG and EVR.
> > Side question, the firmware on MRF website is it for the processor or the FPGA or both? Should I update the processor only or both?
MRF website firmware isn't for VME EVG230 and EVR230-RF, so you should
not use them to update it. From my understanding (not VME), these
firmwares are for FPGA, but I may be wrong, because I don't update any
firmware of VME products.
As Michael mentioned before, it would be better to contact Jukka (MRF)
directly in order to get the real supports from MRF.
HTH,
Han
> I am starting to think this question explains the problem, because few days ago I just noticed in the manual there is update procedure for the FPGA. So when we say firmware update I am not sure processor, FPGA or both.
> Best Regards,
> Abdalla.
> -----Original Message-----
> From: Jeong Han Lee <[email protected]>
> Sent: Tuesday, February 09, 2021 9:30 AM
> Cc: Michael Davidsaver <[email protected]>; [email protected]
> Hi Abdalla,
> Could you explain your hardware model?
> I did its firmware update by using MRF software, and epics-modules/mrfioc2 IOC.
> Usually, it works without any problem. However, there are some NOT MRF generic firmwares, and NOT MRF hardwares I saw in my life. That is the reason why I made the first question.
> Best,
> Han
> On Mon, Feb 8, 2021 at 10:38 PM Abdalla Ahmad via Tech-talk <[email protected]> wrote:
> > Hello Michael
> > Thanks for the feedback. Will try to contact MRF.
> > Best Regards,
> > Abdalla.
> > From: Michael Davidsaver <[email protected]>
> > Sent: Monday, February 08, 2021 7:32 PM
> > Cc: [email protected]
> > On 2/8/21 6:37 AM, Abdalla Ahmad via Tech-talk wrote:
> > > Hello community
> > > This question is not EPICS specific, but I could use some help. We tried downgrading the firmware for spare EVG and EVR boards which have the MRM firmware 005 I think to firmware E403 and D507 respectively. I followed the procedure in the manuals but when I issue the command "u" to start the update process, the telnet session exits with message "Self-programming triggered". I came back after a while and every time I telnet to the board, it seems the device entered a mode where no command is available (only q and x commands), sometimes when the device reboots, I try to dump the memory I get "Addr 0x8000002e: error -1".
> > > I tried re-uploading the firmware, power-cycle, and factory settings but nothing works. Any advice how to fix the firmware update process?
> > Back when I was at BNL I was able to successfully update firmware on several VME boards (I assume that's what you have).  I was always nervous though.
> > I can only recommend contacting MRF.  If you are lucky, and have access to a JTAG programmer, you might be able to directly re-flash the firmware yourself.
RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
Prev: RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Next: Re: caproto ioc alarm value leakage Lauer, Ken via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
