1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Yet another calc record / CPP link problem
To: Ben Franksen <[email protected]>
Date: Tue, 16 Feb 2021 13:22:16 +0000
> How is that possible? If the record was able to process its input links
> (which it apparently did since A..D have the expected values), then
> shouldn't it also process the CALC expression and set VAL accordingly?
Could this be a race condition?  What would happen if there were multiple CA callbacks while the record was processing?  Is it possible for one of the inputs to change state without processing the record again to compute the correct VAL?
From: Tech-talk <[email protected]> on behalf of Ben Franksen via Tech-talk <[email protected]>
Sent: Tuesday, February 16, 2021 4:56 AM
To: EPICS tech-talk
Subject: Yet another calc record / CPP link problem
I have problems with a slightly complicated database that sometimes
"hangs" in an unexpected state because some status bits aren't
propagated as they should be. Investigating the state of the IOC I
tracked the problem down to the following record:
record(calcout,"BPMMUXCB:stTLIO") {
    field(CALC,"A&B&C&D=A|B|C|D?A:VAL")
    field(INPA,"BPMMUX1S16G:stT CPP")
    field(INPB,"BPMMUX1S16G:stL CPP")
    field(INPC,"BPMMUX2S16G:stI CPP")
    field(INPD,"BPMMUX2S16G:stO CPP")
The input records are of type mbbi. The CALC expression is such that we
check if all inputs are equal; if yes, set VAL to one of them, else
don't change VAL.
The problematic state is this: all inputs are zero, yet VAL=1. I checked
that both the input fields (A..D) are zero as well as the PVs that
supply the input values.
Furthermore: processing the record (caput BPMMUXCB:stTLIO.PROC 1) did
/not/ have any effect (VAL remained at 1). However, writing a different
but equivalent expression into CALC field did resolve it: VAL then
became 0 as expected.
This looks similar to https://bugs.launchpad.net/epics-base/+bug/1841634
but note that the calcout here has no ODLY set, so it should (I think)
process synchronously.
I case you wonder: Yes, a simple calc instead of a calcout would have
been sufficient here; that it's a calcout is a left-over from a previous
version. I cannot ATM verify that the calc record has the same behavior.
This problem is very hard to reproduce. The only way I have been able to
reproduce it is to let the Python script that drives the thing in order
to make certain measurements run for a long time and wait until it hangs
(waiting for readbacks to coincide with setpoints after switching the
multiplexor to another channel).
Cheers
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned.  -- Richard Feynman
Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Prev: Detect PV connect and disconnect events in CSS Pogacnik, Matic via Tech-talk
Next: Re: Detect PV connect and disconnect events in CSS Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Next: Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
