1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Yet another calc record / CPP link problem
From: Ben Franksen via Tech-talk <[email protected]>
Date: Tue, 16 Feb 2021 15:50:01 +0100
Am 16.02.21 um 14:22 schrieb Mark Rivers:
>> How is that possible? If the record was able to process its input links
>> (which it apparently did since A..D have the expected values), then
>> shouldn't it also process the CALC expression and set VAL accordingly?
> Could this be a race condition?
It very much looks like one, doesn't it?
>  What would happen if there were
> multiple CA callbacks while the record was processing?  Is it
> possible for one of the inputs to change state without processing the
> record again to compute the correct VAL?
This is what I suspected at first, which is why I explicitly triggered
processing by writing to PROC. This did not have the expected effect (of
re-computing and thus fixing VAL).
The next time this happens I will hopefully be able to get more
information (like doing a full dbpr); any idea what else I could do?
Cheers
Ben
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Ben Franksen via Tech-talk <[email protected]>
> Sent: Tuesday, February 16, 2021 4:56 AM
> To: EPICS tech-talk
> Subject: Yet another calc record / CPP link problem
> I have problems with a slightly complicated database that sometimes
> "hangs" in an unexpected state because some status bits aren't
> propagated as they should be. Investigating the state of the IOC I
> tracked the problem down to the following record:
> record(calcout,"BPMMUXCB:stTLIO") {
>     field(CALC,"A&B&C&D=A|B|C|D?A:VAL")
>     field(INPA,"BPMMUX1S16G:stT CPP")
>     field(INPB,"BPMMUX1S16G:stL CPP")
>     field(INPC,"BPMMUX2S16G:stI CPP")
>     field(INPD,"BPMMUX2S16G:stO CPP")
> The input records are of type mbbi. The CALC expression is such that we
> check if all inputs are equal; if yes, set VAL to one of them, else
> don't change VAL.
> The problematic state is this: all inputs are zero, yet VAL=1. I checked
> that both the input fields (A..D) are zero as well as the PVs that
> supply the input values.
> Furthermore: processing the record (caput BPMMUXCB:stTLIO.PROC 1) did
> /not/ have any effect (VAL remained at 1). However, writing a different
> but equivalent expression into CALC field did resolve it: VAL then
> became 0 as expected.
> This looks similar to https://bugs.launchpad.net/epics-base/+bug/1841634
> but note that the calcout here has no ODLY set, so it should (I think)
> process synchronously.
> I case you wonder: Yes, a simple calc instead of a calcout would have
> been sufficient here; that it's a calcout is a left-over from a previous
> version. I cannot ATM verify that the calc record has the same behavior.
> This problem is very hard to reproduce. The only way I have been able to
> reproduce it is to let the Python script that drives the thing in order
> to make certain measurements run for a long time and wait until it hangs
> (waiting for readbacks to coincide with setpoints after switching the
> multiplexor to another channel).
> Cheers
> Ben
> I would rather have questions that cannot be answered, than answers that
> cannot be questioned.  -- Richard Feynman
Attachment: signature.asc
Description: OpenPGP digital signature
Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Re: Yet another calc record / CPP link problem Mark Rivers via Tech-talk
Prev: RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Next: Re: EPICS latest stable version Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Yet another calc record / CPP link problem Mark Rivers via Tech-talk
Next: Re: Yet another calc record / CPP link problem Michael Davidsaver via Tech-talk
