1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Yet another calc record / CPP link problem
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Ben Franksen <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 16 Feb 2021 08:10:13 -0800
On 2/16/21 2:56 AM, Ben Franksen via Tech-talk wrote:
> I have problems with a slightly complicated database that sometimes
> "hangs" in an unexpected state because some status bits aren't
> propagated as they should be. Investigating the state of the IOC I
> tracked the problem down to the following record:
> record(calcout,"BPMMUXCB:stTLIO") {
>     field(CALC,"A&B&C&D=A|B|C|D?A:VAL")
>     field(INPA,"BPMMUX1S16G:stT CPP")
>     field(INPB,"BPMMUX1S16G:stL CPP")
>     field(INPC,"BPMMUX2S16G:stI CPP")
>     field(INPD,"BPMMUX2S16G:stO CPP")
Loaded a softIoc with this record and four dummy input bi records.
It didn't take me long to find a sequence which exhibits the
"hysteresis" which you describe.  I'm not so quick with the mouse
this morning, so I don't think this is a race condition.
Initially all 5 records are zero.
> epics> dbpf BPMMUX1S16G:stT 1
> DBF_STRING:         "One"
> epics> dbpf BPMMUX1S16G:stL 1
> DBF_STRING:         "One"
> epics> dbpf BPMMUX1S16G:stL 0
> DBF_STRING:         "Zero"
> epics> dbpf BPMMUX1S16G:stT 0
> DBF_STRING:         "Zero"
> epics> dbgf BPMMUXCB:stTLIO
> DBF_DOUBLE:         1
> epics>
The use of "VAL" here confuses me, but I wonder "A&B&C&D=A|B|C|D"
should be "(A&B&C&D)=(A|B|C|D)"?
> The input records are of type mbbi. The CALC expression is such that we
> check if all inputs are equal; if yes, set VAL to one of them, else
> don't change VAL.
> The problematic state is this: all inputs are zero, yet VAL=1. I checked
> that both the input fields (A..D) are zero as well as the PVs that
> supply the input values.
> How is that possible? If the record was able to process its input links
> (which it apparently did since A..D have the expected values), then
> shouldn't it also process the CALC expression and set VAL accordingly?
> Furthermore: processing the record (caput BPMMUXCB:stTLIO.PROC 1) did
> /not/ have any effect (VAL remained at 1). However, writing a different
> but equivalent expression into CALC field did resolve it: VAL then
> became 0 as expected.
> This looks similar to https://bugs.launchpad.net/epics-base/+bug/1841634
> but note that the calcout here has no ODLY set, so it should (I think)
> process synchronously.
> I case you wonder: Yes, a simple calc instead of a calcout would have
> been sufficient here; that it's a calcout is a left-over from a previous
> version. I cannot ATM verify that the calc record has the same behavior.
> This problem is very hard to reproduce. The only way I have been able to
> reproduce it is to let the Python script that drives the thing in order
> to make certain measurements run for a long time and wait until it hangs
> (waiting for readbacks to coincide with setpoints after switching the
> multiplexor to another channel).
> Cheers
> Ben
Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Prev: Re: EPICS latest stable version Timo Korhonen via Tech-talk
Next: pmacAsynCoord in-position vs .MOVN Hidas, Dean via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Next: Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
