1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS latest stable version
From: Timo Korhonen via Tech-talk <[email protected]>
To: Delahaye Olivier <[email protected]>, Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Cc: Pillon Frank <[email protected]>, Zouaoui Djaid <[email protected]>, Sebille Florian <[email protected]>, Patard Charles-Henri <[email protected]>
Date: Tue, 16 Feb 2021 15:23:03 +0000
Hi Olivier,
”the devil is in the details”…
As Ralph pointed out, the process database is backwards compatible, to a very high degree. There may be a few changes here and there but I would be rather confident that this will not be a problem in the upgrade.
However, the environment has had a lot of changes. With “environment” I mean systems that EPICS runs on, for instance VxWorks; if your installation has been running for a while, I guess you might still be at VxWorks versions 6 or even 5.
Getting EPICS to compile on these platforms will have issues, and for version 5 it is practically impossible. So you would have to consider what to do with these, do you want to upgrade VxWorks, or maybe even need to upgrade the hardware. Linux should be easier but you should still be prepared to do a number of the tedious small changes that Ralph mentioned.
Channel Access should not be an issue, I would bet it works without issues in the same way it used to. And pvAccess can run parallel to Channel Access; the “tedious small changes” are not related to pvAccess, you can even opt not to use it at all if you wish (this is certainly not a recommendation, though!)
It is hard to estimate how long the upgrade would take. I assume that the Linux IOCs would be fairly easy to upgrade, but there is still work to get all the drivers and device support updated and tested, etc.
I guess you would also like to update the client machines, even if old applications might work.
But the big issue would be to decide what to do with your VxWorks IOCs – and that depends on what version you have been using so far, at least assuming you still want to continue using VxWorks.
FWIW, we at ESS are not in regular beam production yet, but apart from a few early IOCs (Cryo, developed early) we are all on 7.0(.4)
Best regards,
Timo
From: Tech-talk <[email protected]> on behalf of Delahaye Olivier via Tech-talk <[email protected]>
Reply-To: Delahaye Olivier <[email protected]>
Date: Tuesday 16 February 2021 at 14:55
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Subject: RE: EPICS latest stable version
Hi Ralph,
Thx a lot for your quick answer.
So If I understand well, we should better switch on 7.0 release. I would be quite confident about the stability since you mentionned half of the installations works now with 7.x version.
Just a few more questions (sorry if questions are not clear, EPICS is quite new to me !).
1. What do you mean by tedious small changes ? We've got about 46 IOCs running on LINUX + 20 running on VxWorks. How long would you estimate for the upgrade ?
2. You mentionned pvAcess protocol has been reviewed on 7.0 version. Our equipments rely on Channel Acess protocol. Is it the same one ? Are the "tedious small changes" you are talking about specifically related to the upgrade of the pvAccess protocol ?
3. You mentioned EPICS process database is backward-compatible. It's not clear to me the split between the different component in EPICS framework. But what is backward compatible and what is not ? Because if everything is backward compatible, what do the "tedious small changes" consist of ?
Thx a lot for your support,
Olivier
De : Ralph Lange <[email protected]>
Envoyé : mardi 16 février 2021 12:55:25
À : EPICS Tech Talk
Cc : Pillon Frank; Zouaoui Djaid; Sebille Florian; Patard Charles-Henri; Delahaye Olivier
Objet : Re: EPICS latest stable version
Dear Olivier,
I'm not getting into the "current" vs. "stable" discussion - that depends so much on your personal definition of these two terms that I can only lose.
Let me answer it from a different angle.
·         3.14 is dead and doesn't even get bug fixes anymore. Time to move on. Not an option for new developments.
·         3.15 is supported and will get bugs fixed as they are discovered. For a new development inside an existing 3.15 context, this might be the appropriate option.
·         7.0 is being actively developed, provides the next generation network protocol pvAccess and keeps the robust 3.x IOC below. Recommended for any new developments.
Such a migration will be an effort. No rocket science, for sure, but a lot of tedious small changes and testing, testing, testing. I would not do that more often than necessary.
Most of the changes in EPICS 7 are in the new parts: the pvAccess protocol stack and its integration in the IOC. As long as you don't heavily rely on the pvAccess protocol, the migration risk is pretty low. The EPICS Process Database code is robust and gets new features carefully in a backward-compatible manner, as always.
Channel Access and its wide compatibility range will be the glue that keeps your system together. Migrating one system, even one IOC at a time should not be a big issue.
Bottom line... Don't underestimate the task. You would need good reasons to not go to a recent 7.0 release.
If I remember correctly, an audience poll at one of the last meetings showed that roughly half of the installations have EPICS 7 running somewhere. Can't be completely broken, then.
Cheers,
~Ralph
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
EPICS latest stable version Delahaye Olivier via Tech-talk
Re: EPICS latest stable version Ralph Lange via Tech-talk
RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Prev: Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Next: Re: Yet another calc record / CPP link problem Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Next: Re: EPICS latest stable version Ralph Lange via Tech-talk
