1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: pmacAsynCoord in-position vs .MOVN
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Hidas, Dean" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Feb 2021 14:09:12 -0600
Dean,
Disclaimer: I'm not an expert in delta tau controllers.
EPICS motor drivers usually only report that an axis is moving if the axis status query for the controller reports that an axis is moving. Does the axis have an encoder? How stable is the feedback position when the motor isn't moving?
I suggest looking at MIP (motion in progress) field of the motor record. If the motor record expects a move to be done, but MOVN is still 1, the motor record turns on the 0x8000 (external move) bit of MIP.
Kevin
On 2/16/21 10:32 AM, Hidas, Dean via Tech-talk wrote:
Dear EPICS Experts,
I'm using pmacAsynCoord with a pmac turbo2 brick controller.  What I notice is that occasionally the pmac reports that a move is finished, that the coordinate system is not motion, but the .MOVN field of the motor record stays high despite reaching the desired position and not actually being in motion.  At this point the pmac reports in position, but the motor record does not seem to have any additional control effect (nor should it I believe), ie the .MOVN field stays high but there is no further motion.  Are there any motor record fields or other parameters you might advise having a look at that could have an effect on this?
Thank you in advance for your help,
-Dean Hidas
pmacAsynCoord in-position vs .MOVN Hidas, Dean via Tech-talk
Prev: Re: Yet another calc record / CPP link problem Ben Franksen via Tech-talk
Next: interest in database applications working group Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: pmacAsynCoord in-position vs .MOVN Hidas, Dean via Tech-talk
Next: Re: pmacAsynCoord in-position vs .MOVN J. Lewis Muir via Tech-talk
