1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: pmacAsynCoord in-position vs .MOVN
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Hidas, Dean" <[email protected]>
Date: Tue, 16 Feb 2021 15:10:44 -0600
On 02/16, Hidas, Dean via Tech-talk wrote:
> I'm using pmacAsynCoord with a pmac turbo2 brick controller.  What I notice is that occasionally the pmac reports that a move is finished, that the coordinate system is not motion, but the .MOVN field of the motor record stays high despite reaching the desired position and not actually being in motion.  At this point the pmac reports in position, but the motor record does not seem to have any additional control effect (nor should it I believe), ie the .MOVN field stays high but there is no further motion.  Are there any motor record fields or other parameters you might advise having a look at that could have an effect on this?
Hi, Dean!
Haven't seen that before.  I initially thought it might be an issue I
reported a while ago
  https://github.com/epics-modules/tpmac/pull/4
but after reading your description of the problem more carefully, I
don't think it's the same thing.
Where did you get pmacAsynCoord?  There seems to be at least three PMAC
drivers floating around that I know of:
1. https://www.gmca.aps.anl.gov/TPMAC2/
2. https://github.com/epics-modules/tpmac
3. https://github.com/dls-controls/pmac
#1 is the original, #2 seems to be a friendly fork of #1, and #3 is a
driver for which I don't know its lineage.
Also, what version of the driver are you using?
Lewis
Re: pmacAsynCoord in-position vs .MOVN Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
pmacAsynCoord in-position vs .MOVN Hidas, Dean via Tech-talk
Prev: Re: EPICS latest stable version Michael Davidsaver via Tech-talk
Next: SkySpark Analytics EPICS interface Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: pmacAsynCoord in-position vs .MOVN Kevin Peterson via Tech-talk
Next: Re: pmacAsynCoord in-position vs .MOVN Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
