1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS latest stable version
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Kevin Peterson <[email protected]>, Delahaye Olivier <[email protected]>
Cc: Pillon Frank <[email protected]>, Zouaoui Djaid <[email protected]>, Sebille Florian <[email protected]>, Patard Charles-Henri <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Feb 2021 12:46:43 -0800
On 2/16/21 12:25 PM, Kevin Peterson via Tech-talk wrote:
> Olivier,
> I've seen CA misaligned protocol errors on IOCs at the APS in the past.  I believe they were caused by network security scans run by the IT group.  There was a strong correlation between the error messages and shutdown days, which is the only time IT scans the beamlines.
cf. another recent example https://epics.anl.gov/tech-talk/2021/msg00072.php
The exact wording the the warning depends on the Base version(s) involved.
Seeing messages like this occasionally is almost certainly a non-CA client attempting
to connect to a CA server.  Actual CA clients retry continually, so any real problem
would be much more verbose.
> IOCs usually didn't need to be restarted after the errors occurred.  I believe Windows IOCs were the exception.  I vaguely recall the scans crashing Windows IOCs.
Any misbehavior associated with malformed message warnings should be reported as a bug.
> Kevin
> On 2/16/21 5:15 AM, Delahaye Olivier via Tech-talk wrote:
>> Hi,
>> I'm working at GANIL in Caen, France.
>> We are currently using EPICS 3.14.12.4. We are facing issues about UDP CAS. (UPD: "CAS: Missaligned protocol rejected).
>> For that, we are wondering whether or not it would be interesting to switch on a more "up to date" version.
>> I would like to know what is the latest "stable" version of EPICS ?
>> I read in your download page there was "stable" versions and "current" versions. What are exactly the differences between "current" and "stable" ?
>> Are current versions stable or not ?
>> Thx for your answer,
>> Olivier Delahaye
>> /Préservons notre environnement, n’imprimez ce mail que si nécessaire./
>> /Preserve our environment, print this email only if necessary./
RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Re: EPICS latest stable version Kevin Peterson via Tech-talk
Prev: Re: EPICS latest stable version Kevin Peterson via Tech-talk
Next: Re: pmacAsynCoord in-position vs .MOVN J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: EPICS latest stable version Delahaye Olivier via Tech-talk
