1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: How to capture messages generated by PyEpics?
From: "Li, Ji via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 18 Feb 2021 22:52:04 +0000
I'm trying to capture CA messages targeting a specific PV on the IOC server with Wireshark (v1.12.1) and Michael Davidsaver's cashark plugin (ca.pv or ip.addr as the filter). Wireshark was able to capture messages generated by caget/caput commands ran from bash. When I get/set from PyEpics (tried both PV module and CA module), the program was able to successfully get the up-to-date value of the PV and set new value to it, but no messages showed up. Doesn't PyEpics communicate using CA protocol messages? Are there specific filter/configuration to be done in Wireshark to show these messages? Thanks.
-Ji Li
RE: How to capture messages generated by PyEpics? Mark Rivers via Tech-talk
Prev: Re: Identical Process Variable names on Multiple Servers Michael Davidsaver via Tech-talk
Next: RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Job opportunity at FRIB Konrad, Martin via Tech-talk
Next: RE: How to capture messages generated by PyEpics? Mark Rivers via Tech-talk
ANJ, 18 Feb 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
