1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Identical Process Variable names on Multiple Servers
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Fri, 19 Feb 2021 00:11:56 +0000
Thanks for everyones input, will keep debugging I am guessing it must be some sort of routing issue or not setting an env variable correctly.
Does anyone have a good example of when you would use the CAGateway and CARepeater?
Also does doing broadcast addressing like 192.168.1.255 the same as implementing the CARepeater?
-----Original Message-----
Sent: Thursday, February 18, 2021 2:03 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: [email protected]
Subject: Re: Identical Process Variable names on Multiple Servers
On 2/18/21 1:06 PM, Manoussakis, Adamandios via Tech-talk wrote:
> Sorry I think I may have left out part the IPs are for example
> 192.168.1.40 and 192.168.2.50.  They exist on different subnets and I didn’t have trouble at first running one IOC on say 192.168.1.40 and having 192.168.2.50 be the client doing caget/camonitor.
> I have the client(192.168.2.50) env variable CA_ADDR_LIST=192.168.1.40
> and it was working fine but now that I have switched things up and I have 192.168.1.40(CA_ADDR_LIST=192.168.2.50) be the client and 192.168.2.50 have the single IOC running it doesn’t seem to want to communicate.
> Which led to me believe I might have just gotten lucky before when it was working and I am missing a piece of the puzzle such as using cagateway or like you have mentioned broadcast addressing.  When you stated to set both to the same broadcast address, do you mean that 192.168.1.40 machine would have 192.168.2.255 and the 192.168.2.50 machine would have 192.168.1.255 set under CA ADDR_LIST respectively.
I didn't read closely enough and was assuming that .1 and .2 were referring to two hosts on the same subnet.  My comment about broadcast addresses would only apply if both where on the same subnet.
Actually, you might check to see if your router is configured to route IPv4 multicasts between these two subnets.  If it is, then you could use the new-ish mcast search feature.  If it is, then you can add a (hopefully unused) multicast address to EPICS_CA_ADDR_LIST and also set EPICS_CA_MCAST_TTL=2
> *From:* Tech-talk <[email protected]> *On Behalf Of *Ralph
> Lange via Tech-talk
> *Sent:* Thursday, February 18, 2021 8:26 AM
> *To:* EPICS Tech Talk <[email protected]>
> *Subject:* Re: Identical Process Variable names on Multiple Servers
> On Thu, 18 Feb 2021 at 16:14, Michael Davidsaver <[email protected] <mailto:[email protected]>> wrote:
>     On 2/18/21 7:01 AM, Ralph Lange via Tech-talk wrote:
>     > When using an explicit IP for the name search, only the /last/ IOC started on that machine will answer.
>     FYI. first vs last depends on host OS, and as I recall windows and linux differ.
> Hm! I was not aware of that at all. Will verify and update the README.
>     2. mis-configured broadcast address
>     Both the .1 and .2 host must have the same broadcast address set.
> As .1 and .2 are different networks, it actually depends on the structure.
> Always: The broadcast addresses must match between the IOC host (receiving the broadcast) network configuration and the client (sending the broadcast) ADDR_LIST setting.
> If the client host has a network interface into the IOC host network: The client host network configuration on that interface must also match.
> If there is a switch between the two networks: The switch needs to be configured to forward "directed broadcasts".
> Cheers,
> ~Ralph
Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Re: Identical Process Variable names on Multiple Servers Mark Rivers via Tech-talk
RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Re: Identical Process Variable names on Multiple Servers Ralph Lange via Tech-talk
Re: Identical Process Variable names on Multiple Servers Michael Davidsaver via Tech-talk
Prev: How to capture messages generated by PyEpics? Li, Ji via Tech-talk
Next: RE: How to capture messages generated by PyEpics? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Identical Process Variable names on Multiple Servers Michael Davidsaver via Tech-talk
Next: RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
