1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Multiple IOCs on one host Issue
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>
Date: Thu, 18 Mar 2021 17:02:13 -0500
On 03/18, Manoussakis, Adamandios via Tech-talk wrote:
> Setup is as follows:
> Client 192.168.1.50
> Client running caget PV1
> Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
> Host 192.168.2.100
> Host running 4-5 IOCs (script is in both of the /etc/network/if-up/down.d folders and have been made executable)
> Env variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
Those aren't the right environment variables.  You might be abbreviating
the names on purpose, but I would recommend you state the exact names
you're using so that no one has to guess what you mean, and also just in
case you've got a typo in any of them.
Lewis
RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Prev: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Next: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
