1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Multiple IOCs on one host Issue
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Date: Thu, 18 Mar 2021 22:34:15 +0000
Hi Lewis,
Env Vars are
Host setup
EPICS_CA_ADDR_LIST=Client IP
EPICS_CA_AUTO_ADDR=YES
Client setup
EPICS_CA_ADDR_LIST=Host IP
I don't think the env variables are the cause in this case but I did try looking at the iptables --list and --list-rules after manually running Ralphs script with sudo and wasn't seeing the added rules from the script.  I would think its possible to manually sudo run the script to get them added but I am not that familiar with it.
-----Original Message-----
Sent: Thursday, March 18, 2021 3:02 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: 'Ralph Lange' <[email protected]>; [email protected]
Subject: Re: Multiple IOCs on one host Issue
On 03/18, Manoussakis, Adamandios via Tech-talk wrote:
> Setup is as follows:
> Client 192.168.1.50
> Client running caget PV1
> Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
> Host 192.168.2.100
> Host running 4-5 IOCs (script is in both of the
> /etc/network/if-up/down.d folders and have been made executable) Env
> variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
Those aren't the right environment variables.  You might be abbreviating the names on purpose, but I would recommend you state the exact names you're using so that no one has to guess what you mean, and also just in case you've got a typo in any of them.
Lewis
Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
Prev: Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
Next: measComp R3-0 available Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
