1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: measComp R3-0 available
Date: Thu, 18 Mar 2021 23:43:58 +0000
Folks,
Release R3-0 of the measComp module is now available.
These are some items from the R3-0 release notes:
  - Changed the method used to specify the device in the constructors and the startup script.
  - The second argument the configuration commands in the startup script (e.g. `drvMultifunctionConfigure()`)
      is no longer a `boardNum` integer , it is a `uniqueID` string.
      - For USB devices the `uniqueID` is the serial number, which is printed on the device (e.g. `"01F6335A"`).
      - For Ethernet devices the `uniqueID` can either be the MAC address (e.g. `"00:80:2F:24:53:DE"`),
        or the IP address (e.g. `"10.54.160.216"`).
        The MAC address or IP address can be used for devices on the local subnet,
        while the IP address must be used for devices on other subnets.
    - There is a new iocsh command, `measCompShowDevices`. This will list all Measurement Computing USB devices
      attached to the computer running the IOC, as well as all Measurement Computing Ethernet devices on the subnet.
  - Added support for the USB-TEMP and USB-TEMP-AI models.
    - These support reading temperature with RTD, thermocouple, thermistor, and semiconductor sensors.
    - The USB-TEMP supports up to 8 temperature inputs.
    - The USB-TEMP-AI supports up to 4 temperature inputs and 4 24-bit voltage inputs.
  - Converted documentation from HTML to Markdown (this document) and ReST (other documentation) at
    https://epics-meascomp.readthedocs.io/en/latest/.
  - Changed the OPI screens to be modular, using subscreens.  This works well because many devices have
    identical functional blocks.  This is much easier to maintain.
  - Removed support for the USB-4303.  This module is obsolete and has not been available for many years.
    The USB-CTR04/08 should be used instead.
The source repository is on Github:
https://github.com/epics-modules/measComp
The documentation is here:
The release notes are here:
https://github.com/epics-modules/measComp/blob/master/RELEASE.md
Prev: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Next: Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: 8671B Synthesized CW Generator (GPIB) Ernesto Paiser via Tech-talk
Next: Job Opening at SLAC National Accelerator Laboratory Zelazny, Michael Stanley via Tech-talk
