1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Cant compile makeBaseApp.pl directories with make
From: "Siddons, David via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Wed, 24 Mar 2021 12:56:19 +0000
Hi Marco,
   You need to install libreadline-dev:
sudo apt install libreadline-dev.
Pete.
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Wednesday, March 24, 2021 8:52 AM
To: [email protected] <[email protected]>
Subject: Cant compile makeBaseApp.pl directories with make
Hello, im kind of newbie into EPICS and im trying to understand how to create an IOC with the EPICS getting started tutorials. I created the $HOME/EPICS/TEST/testIoc directory on a debian 9 docker container and used the makeBaseApp.pl command to create the example app. however, when i use the make command, i get the following error:
/usr/bin/ld: cannot find -lreadline
collect2: error: ld returned 1 exit status
/usr/local/epics/base/configure/RULES_BUILD:305: recipe for target 'libtestIocSupport.so' failed
make[3]: *** [libtestIocSupport.so] Error 1
make[3]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp/src/O.linux-x86_64'
/usr/local/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp/src'
/usr/local/epics/base/configure/RULES_DIRS:83: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/home/marco/EPICS/TEST/testIoc/testIocApp'
/usr/local/epics/base/configure/RULES_DIRS:83: recipe for target 'testIocApp.install' failed
make: *** [testIocApp.install] Error 2
can anyone give me a hint on how to understand what is happening?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Cant compile makeBaseApp.pl directories with make Marco A. Barra Montevechi Filho via Tech-talk
Prev: Cant compile makeBaseApp.pl directories with make Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Cant compile makeBaseApp.pl directories with make Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
