Hello,
I am using the latest Area Detector R3-10 on Ubuntu 20.04 focal (x86-64). Unfortunately the Flea2 camera which is connected to the computer is not detected: Startup script: epicsEnvSet("IOC","iocPointGrey") epicsEnvSet("TOP","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC") epicsEnvSet("ADPOINTGREY","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/../..") epicsEnvSet("SUPPORT","/home/beamline/EPICS/synApps/support") epicsEnvSet("ASYN","/home/beamline/EPICS/synApps/support/asyn-R4-41") epicsEnvSet("AREA_DETECTOR","/home/beamline/EPICS/synApps/support/areaDetector-R3-10") epicsEnvSet("ADSUPPORT","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADSupport") epicsEnvSet("ADCORE","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADCore") epicsEnvSet("AUTOSAVE","/home/beamline/EPICS/synApps/support/autosave-R5-10-2") epicsEnvSet("BUSY","/home/beamline/EPICS/synApps/support/busy-R1-7-3") epicsEnvSet("CALC","/home/beamline/EPICS/synApps/support/calc-R3-7-4") epicsEnvSet("SNCSEQ","/home/beamline/EPICS/synApps/support/seq-2-2-8") epicsEnvSet("SSCAN","/home/beamline/EPICS/synApps/support/sscan-R2-11-4") epicsEnvSet("DEVIOCSTATS","/home/beamline/EPICS/synApps/support/iocStats-3-1-16") epicsEnvSet("EPICS_BASE","/home/beamline/EPICS/base-7.0.5") errlogInit(20000) dbLoadDatabase("/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/dbd/pointGreyApp.dbd") : : # Prefix for all records epicsEnvSet("PREFIX", "13PG1:") # Use this line for the first Point Grey camera in the system epicsEnvSet("CAMERA_ID", "0") # Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera epicsEnvSet("CAMERA_ID", "9211601") : : pointGreyConfig("PG1", 18402100, 0x1, 0) 2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found 2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number. 2021/03/25 17:56:30.651 pointGrey:pointGrey: camera connection failed (3) Number of cameras detected: 0 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found 2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number. 2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera() Supported properties ./start_epics: line 1: 78175 Segmentation fault (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd ----------------------------------------------------------------------------------------------- kernel reports the following problem: 692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000] [692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89 Does anybody have an idea what might be wrong? Best Regards Mirek
ANJ, 26 Mar 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
