1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: Re: Area Detector and Flea2 camera problem
From: Jeong Han Lee via Tech-talk <tech-talk at aps.anl.gov>
To: Miroslaw Dach <mdach at lbl.gov>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 25 Mar 2021 18:44:41 -0700
Hi Mirek,
My suspicion remains in the following options:
> # Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera
> epicsEnvSet("CAMERA_ID", "9211601")
> pointGreyConfig("PG1", 18402100, 0x1, 0)
The second arg of pointGreyConfig is Camera ID, The first option is
"epics variable", but the second is you use the hardcode value.
If it is not your case, it is better to check the connection through
the vendor software whether you can connect or not.
Best,
Han
> 2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found
> 2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
> 2021/03/25 17:56:30.651 pointGrey:pointGrey:  camera connection failed (3)
> Number of cameras detected: 0
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
> 2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera()
> Supported properties
> ./start_epics: line 1: 78175 Segmentation fault      (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd
> kernel reports the following problem:
> 692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000]
> [692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89
> Does anybody have an idea what might be wrong?
> Best Regards
> Mirek
Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Prev: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Next: Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
ANJ, 25 Mar 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
