1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: Changing EPICS general Purpose Thread's Priorities
From: William Layne via Tech-talk <tech-talk at aps.anl.gov>
To: jun-ichi.odagiri at kek.jp
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Sat, 27 Mar 2021 02:44:18 -0400
A few other ideas is that you can try multiple callback threads or splitting into multiple IOCs.
On Sat, Mar 27, 2021, 2:32 AM jun-ichi.odagiri--- via Tech-talk <tech-talk at aps.anl.gov> wrote:
Dear Ralph
Thanks for your reply.
> Changing priorities of callback, driver or communication threads with
> respect to database processing.
> Which is exactly what your question is about.
I got it. Thanks!
> Why do you want to change the priority of "CAS-TCP"? Note that this is
not
> a "general purpose thread", but one of the core threads of the Channel
> Access server.
Here is the reason.
An IOC controls many power supplies of something. The IOC is polling the
status of the power supplies at a SCAN rate of 0.1 seconds. When the
number of the power supplies increases, the IOC starts to lose commands
sent from an CA-client. I thought that the problem would be solved if
I give the "CAS-TCP" a priority which is higher than that of "scan-0.1".
But, on the second thought, I realized that there is no need to do that
because the commands sent from the CA-client will be queued on the IOC-
side.
As far as some time is left for the "CAS-TCP" to run, the loss of
commands
should not occur.
Am I right?
I guess the origin of the problem would not be an issue of priority but
an issue of throughput. So, I decided to solve the problem by improving
the efficiency of the polling of the status of the power supplies.
Fortunately, there is a way to do that.
>     The default priorities of the EPICS IOC threads are well-chosen.
They
> have been proven to ensure reliable IOC operation and communication,
in
> many installations, under a variety of circumstances.
I am really aware of this. That is the reason why I noticed my
misunderstanding
of the situation.
Best regards,
J.Odagiri at KEK
----- Original Message -----
> On Fri, 26 Mar 2021 at 08:09, jun-ichi.odagiri--- via Tech-talk <
> > Here is my question.
> > Can I change the priority of "CAS-TCP" thread and "scan-10"
> > thread so that the former is given a higher priority than
> > that of the latter without modifying any source files in
> > base?
> > Does the site you guided me to answer the question?
> As per the README of the MCoreUtils, one of its features is
> The MCoreUtils facility allows rule-based manipulation of thread
> properties, so that things like changing a priority will apply to all
> threads with a name matching a specific pattern, whenever they will be
> created on that IOC.
not
> Access server.
> (From the MCoreUtils documentation:)
> Warning
They
in
>     Manipulating the real-time properties, especially scheduling
policies
> and priorities, may have unwanted side effects. Use this feature
sparingly,
> and test well.
> Cheers,
> ~Ralph
Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Re: MRF kernel module, failed to map BARS Michael Davidsaver via Tech-talk
RE: MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Re: Changing EPICS general Purpose Thread's Priorities Jeong Han Lee via Tech-talk
Re: Changing EPICS general Purpose Thread's Priorities Ralph Lange via Tech-talk
Prev: Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
Next: Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
ANJ, 27 Mar 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
